L2TP tunel - není to ideální
Rudolf Dvořák
Příspěvekod Rudolf Dvořák » 13 years ago
Pěkný den,
mám nezi dvěma lokalitami nastavený L2TP tunel. V obouch MK ROS v5.10. Problém je v tom, že když to naskočí tak to běží nějkej čas a pak spojení spadne. A dokud nerestuju oba MK, tak to proste zpatky neběží. Posílám exporty a prosím, jestli se mi někdo kouknete kde mám co zmršený. Už to trvá nějakou dobu a štve mě to. Díky moc Ruda
[admin@aa-mk1] > ppp export
# jan/23/2012 17:00:31 by RouterOS 5.10
# software id = LU2E-HESB
/ppp profile
set default change-tcp-mss=yes name=default only-one=default use-compression=default use-encryption=default use-mpls=default use-vj-compression=default
add bridge=BRIDGE-lan change-tcp-mss=yes dns-server=10.1.1.11,10.1.16.11 local-address=172.16.10.1 name=pptp only-one=no remote-address=pool-vpn use-compression=default use-encryption=required use-mpls=default use-vj-compression=default
add address-list=MK_admin-address_list change-tcp-mss=default local-address=172.31.255.1 name=MK_admin only-one=default use-compression=yes use-encryption=required use-mpls=default use-vj-compression=yes
add change-tcp-mss=yes name=high-sec only-one=default use-compression=default use-encryption=required use-mpls=default use-vj-compression=default
set default-encryption change-tcp-mss=yes name=default-encryption only-one=default use-compression=default use-encryption=yes use-mpls=default use-vj-compression=default
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/ppp secret
add caller-id="" disabled=no limit-bytes-in=0 limit-bytes-out=0 local-address=172.16.1.1 name=ab password=*** profile=pptp remote-address=172.16.1.2 routes="10.1.16.0/23 172.16.1.2 10" service=l2tp
[admin@aa-mk1] > ip route export
/ip route
add comment="DEFAULT GATEWAY" disabled=no distance=254 dst-address=0.0.0.0/0 gateway=172.20.33.1 scope=30 target-scope=10
add disabled=no distance=11 dst-address=10.1.16.0/23 gateway=172.16.2.1 scope=30 target-scope=10
[admin@aa-mk1] > interface l2tp-client export
/interface l2tp-client
add add-default-route=no allow=mschap2 connect-to=**ip of ab** dial-on-demand=no disabled=no max-mru=1460 max-mtu=1460 mrru=disabled name=ab password=*** profile=high-sec user=aa
[admin@ab-vmk1] > ppp export
# jan/23/2012 17:02:44 by RouterOS 5.10
# software id = Q3SK-N6Y9
/ppp profile
/ppp aaa
/ppp secret
add caller-id="" disabled=no limit-bytes-in=0 limit-bytes-out=0 local-address=172.16.2.1 name=aa password=*** profile=high-sec remote-address=172.16.2.2 routes="10.1.0.0/20 172.16.2.2 10" service=l2tp
[admin@ab-vmk1] > ip route export
/ip route
add comment="DEFAULT GATEWAY" disabled=no distance=254 dst-address=0.0.0.0/0 gateway=10.30.61.126 scope=30 target-scope=10
add disabled=no distance=11 dst-address=10.1.0.0/20 gateway=172.16.1.1 scope=30 target-scope=10
[admin@ab-vmk1] > interface l2tp-client export
add add-default-route=no allow=mschap2 connect-to=**ip of aa** dial-on-demand=no disabled=no max-mru=1460 max-mtu=1460 mrru=disabled name=aa password=*** profile=high-sec user=ab
