Toughswitch
David2006
Toughswitch
Super, tohle to konečně časem vykope poslední pozůstatky Mikrotiku v mé síti :mrgreen: .
Toughswitch!
8 port gigabit managed POE
Supports VlAN, Interface bonding, STP and alerts
POE passthrough - power your devices off the switch
Traffic limiting
Supports jumbo frame (real not 2000)
No pricing set yet.
SNMP support
Q: can it be powered by PoE?
A: no
Q: why is there a USB port?
A: possibility of backups, 3G device.
Q: 802.3af support?
A: no. Only passive
Q: will it reboot when we change a setting?
A: based off of airOS. However that instant changes are in the feature list for airOS.
Q: ports are gige. Will there be a gige radio?
A: YES!
emm, to je switch ze? dokud to nebude router, bude to na pikacu. lidi routujou, prober se, proto na sajtech je kabelovej router s mikrotikem. Pokud ma sit za neco stat, bude tam router.
Kolik to bude stat? pro napajeni mikrotiku by to bylo pekny :-)
David2006
Používám VLANy prober se Ty :mrgreen: .
a vlany se bridguji, i vlanovej broadcast proleti celou l2 siti
DHCP-snooping? RA-guard? Loopback-detection? Storm-control? Umí?
martinm
Příspěvekod martinm » 14 years ago
foto z AWC Las Vegas s novinkami Toughswitch , Rocet Titanium a Edge OS https://www.facebook.com/wificentrum
EdgeOS = Router Platform
Based on vyatta, open-source router OS. Performs major routing features. Command line and web UI. Integration with other UBNT devices.
UBNT custom hardware. Multi-core MIPS64, HW-accelerated packet processing (same processors used in Juniper and Cisco routers)
Edge OS. To vypadá zajímavě. Ale cena bude masitá.
David2006
Ty se drž raději svého Mikrotikáckého routovacího a shapovacího kopita :mrgreen: . Cena bude zajímavá, celé to mělo být spíše takto:
EdgeOS Router Platform
Performs major routing features......OSPF, RIP, BGP, RIP, VLAN, Bridge, Bonding, GRE, VRRP, Firewall, NAT, DHCP, QoS, IPSec, PPTP, PPPoE. Command line and web UI.
Disruptive Price
So far the base software is running on the hardware platform and the hardware design is already in progress. UI team is working on design currently. Target release is Q2 of 2012
vyatta je open source?
Docela se mě to líbí. Nějaké obrázky pro ty kteří nemají FB
už aby to tu bylo
soooc
proč to sakra neni do racku!
Petr Šlinz
UBNT mám rád!
zrovna jsem se chtěl zeptat na to samí. Mohl by bejt u toho třeba jenom držák do racku aspoň na jednu stranu.
David2006
Si to tam pak navrtej a dej pokoj s blbostma :mrgreen: .
měl by ses přestat chovat jak zákazník apple.
