Verze 5.7
Verze 5.7
What's new in 5.7 (2011-Sep-14 10:54):
*) ovpn client - fixed crash when user name or password together
were longer than 11 symbols;
*) sstp client - added an option to skip
server address verification from certificate;
*) fixed problem - router crashed sometimes when using USB modem;
*) userman - show overall totals, show user totals if user has more
than one entry;
*) lcd - retrieving '/system lcd page' configuration did not work with
hundreds of interfaces;
*) webfig - added ability to reorder fields in skins;
*) webfig - added ability to add/remove new tabs & separators in skins;
*) webfig - added ability to add any field to special status page;
*) webfig - fixed problem when user sometimes got logged out with message
"internal server error";
*) webfig - logout didn't log user out from router;
*) webfig - added System/Password for changing user's own password;
*) system reset-configuration - if keep-users is specified ssh user keys are
preserved as well;
*) ipsec - new exchange mode (main-l2tp) for l2tp tunnel users to allow
FQDN as a peer ID with preshared key authorization in main mode;
*) ssh - fix possible server crash when connection is interrupted;
*) improved ipv4 forwarding performance on all boards with simple configuration
by up to 30%;
*) add passthrough setting to change-dscp, change-ttl, change-mss,
strip-ipv4-options, change-hop-limit mangle targets;
*) ipsec - fixed problem of RB1200 rebooting when large amount of UDP traffic is
sent through IPsec;
*) sniffer - added more useful packet filtering options, also available as quick
mode command parameters;
Maxik
hlasim konecne funkcniho ovpn klienta naposled funkcni ve verzi 5beta1 a 4x.
no prosím zkuste někdo na x86 jestli už nezlobí ty ipv6 adresy, jak psalo že jsou invalid, pokud to nepravili, tak to ani instalovat nebudu :|
ef
Příspěvekod ef » 14 years ago
A kdy ti to psalo invalid? Já mám verzi 5.6 na vícero místech jak na x86 tak na RB a vše v pořádku.
no furt to píše, ovšem na RBčkách to jede, viz mé demo www.matejov.org demo demo
a mě na bráně vypadává IPv6ka na wanu. Jednou za čas je IPv6 nedostupná a musí se vypnout a zapnou iface. Jo a jistě, invalid v ipv6 address jsem už měl taky.
petr
Příspěvekod petr » 14 years ago
Zkušebně jsem upradoval 3 RB (RB600, RB600a, RB433AH) Všechny už stačily poslat autosupout.rif (několik let jsem o nich něvěděl) a Dude i ispadmin mají problémy s načítáním informací o některých rozhraních. Takže jsem se raději zase vrátil k v.5.6 :(
Petr Kraus
Přimda
kraus@primda.cz
Flegmosmoke
Příspěvekod Flegmosmoke » 14 years ago
petr píše:Zkušebně jsem upradoval 3 RB (RB600, RB600a, RB433AH) Všechny už stačily poslat autosupout.rif (několik let jsem o nich něvěděl) a Dude i ispadmin mají problémy s načítáním informací o některých rozhraních. Takže jsem se raději zase vrátil k v.5.6 :(
Toto potvrzuji...
já dal na klasickou RB433 a jede to bez problémů
RB 800 , RB 600 ,groove, rb 711 vse jed eok
Martin_H
Příspěvekod Martin_H » 14 years ago
Nahrál jsem na jednu RB433AH a v ispadminovi mi to porad posila kill procesy do logu a na 711 mmcx po nahrati nejde upgradnout bios jak na 2.36 tak na 2.37 z 2.35.....
tomas_m
Příspěvekod tomas_m » 14 years ago
Martin_H píše:Nahrál jsem na jednu RB433AH a v ispadminovi mi to porad posila kill procesy do logu a na 711 mmcx po nahrati nejde upgradnout bios jak na 2.36 tak na 2.37 z 2.35.....
ano je to tak ispadmin ma problem z verziou 5.7 (neviem ci na vsetkych Rb ) ale 433,433Ah urcite takze stable s ispadminom zostava stale 5.6 .
pthv
Příspěvekod pthv » 14 years ago
tomas_m píše:
Problem je i na x86 a to je tam myslim p4 3GHz.
Hobbit
Příspěvekod Hobbit » 14 years ago
Dneska jsem nahrnul tuto verzi do RB450G - a ejhle, DHCP a management vykotlili CPUcko na 100%.
Nasledoval downgrade na 5.6 a OK, vse jelo normalne.
Zkusebni upgrade na 5.7 - a opet, DHCP vykotlilo procesor.
Takze 5.7 na RB450G nepruchozi, na 5.6 je to v normalu.
...Linux is like a Wigwam. No Windows, no Gates, Apache inside...
ano, správně, 72 DHCP serverů na RB450G. Jinak na zahraničnim serveru si taky lidi na to stěžovali. Ale ne u RB450 ale obecně u v5.7.
