Verze 4.3
CANOPA
Verze 4.3
Příspěvekod CANOPA » 16 years ago
uz jste nekdo zjistl co je v ni noveho?Pro mips uz existuje :-)
Petr S.
Příspěvekod honzam » 16 years ago
Už vyšla
What's new in 4.3:
*) API - fixed possible crash when running concurrent commands;
*) console - fixed logging commands: 'warning', 'error' and 'debug' were
all using 'info' topic;
*) bgp - added routing-table configuration option for instances;
*) bgp - added 'as-override' and 'passive' configuration options for peers;
*) bgp - added support for Site of Origin extended communities;
*) bgp - fixed some network issues;
*) ospf - fixed problem: when last neighbor on multi-access interface disappeared,
incorrect RouterLSA was generated on designated router;
*) metarouter - allow to specify metarouter's memory size when importing image;
*) firewall - added 'routing-table' matcher;
*) fixed problem - e1000 driver did not work in virtual machines;
Stanislav Hrncir
Příspěvekod Stanislav Hrncir » 16 years ago
tak poďme na ten spektrák :)
The spectrum analyzer can scan all frequencies supported by your wireless card, and plot them directly in console. Exact frequency span depends on card. Allowed ranges on r52n: [4790; 6085], [2182; 2549].
Wireless card can generate 4us long spectral snapshots for any 20mhz wide channel. This is considered a single spectral sample.
To improve data quality spectrum is scanned with 10mhz frequency increments, which means doubled sample coverage at each specific frequency (considering 20mhz wide samples).
Console
Spectral History
/interface wireless spectral-history <wireless interface name>
Plots spectrogram. Legend and frequency ruler is printed every 24 lines. Numbers in the ruler correspond to the value at their leftmost character position. Power values that fall in different ranges are printed as different colored characters with the same foreground and background color, so it is possible to copy and paste terminal output of this command.
* value -- select value that is plotted on the output. 'interference' is special as it shows detected interference sources (affected by 'classify-samples' parameter) instead of power readings, and cannot be made audible.
* interval -- interval at which spectrogram lines are printed.
* duration -- terminate command after specified time. default is indefinite.
* buckets -- how many values to show in each line of spectrogram. This value is limited by the number of columns in terminal. It is useful to reduce this value if using 'audible'.
* average-samples -- Number of 4us spectral snapshots to take at each frequency, and calculate average and maximum energy over them. (default 10)
* classify-samples -- Number of spectral snapshots taken at each frequency and processed by interference classification algorithm. Generally more samples gives more chance to spot certain type of interference (default 50)
* range --
o 2.4ghz - scan whole 2.4ghz band
o 5ghz - scan whole 5ghz band
o current-channel - scan current channel only (20 or 40 mhz wide)
o range - scan specific range
* audible=yes -- play each line as it is printed. There is a short silence between lines. Each line is played from left to right, with higher frequencies corresponding to higher values in the spectrogram.
Spectral Scan
/interface wireless spectral-scan <wireless interface name>
Continuously monitor spectral data. This command uses the same data source as 'spectral-history', and thus shares many parameters.
Each line displays one spectrogram bucket -- frequency, numeric value of power average, and a character graphic bar. Bar shows average power value with ':' characters and average peak hold with '.' characters. Maximum is displayed as a lone floating ':' character.
* show-interference -- add column that shows detected interference sources.
Types of possibly classified interference:
* bluetooth-headset
* bluetooth-stereo
* cordless-phone
* microwave-oven
* cwa
* video-bridge
* wifi
holt některé věci v changelogu neuvidíte
Naposledy upravil(a) Stanislav Hrncir dne 25 Nov 2009 15:30, celkem upraveno 1 x.
jak jsi na to přišel?
haklina
Příspěvekod haklina » 16 years ago
jaká je na to zapotřebí karta ? zkoušel sem z cm9, rb2 i ubnt a nic. Nekde je tam zminka o r52n ale tu ted nemam zrovna poruce.
Stanislav Hrncir
haklina píše:jaká je na to zapotřebí karta ? zkoušel sem z cm9, rb2 i ubnt a nic. Nekde je tam zminka o r52n ale tu ted nemam zrovna poruce.
r52n nebo něco s tím chipsetem, nevidím důvod aby to nefungovalo i najiných ale každý má jinou marketingovou politiku,.. tak proč to povolit na starých kartách.. je na toom krásně vidět jak se rozléná 11.n na dva kanály a podobně..
haklina
nemuzete hodit nekam screen jak to vypadá ... pripadne i png výstup
Stanislav Hrncir
haklina píše:nemuzete hodit nekam screen jak to vypadá ... pripadne i png výstup
du udelat screeny 11n
Stanislav Hrncir
ready
(23.6 KiB) Staženo 3878 x
(14.87 KiB) Staženo 3891 x
porad nechapu jak to souvisi s verzi 4.3
Stanislav Hrncir
honzam píše:porad nechapu jak to souvisi s verzi 4.3
jestli to nebude tim
ze je to ve v 4.3 novinka a v changelogu to neni tak o tom skoro nikdo nevi
Stanislav Hrncir píše:
A jak se člověk dozví o nové funkci která není v changelogu?
SPCom
Příspěvekod SPCom » 16 years ago
Jenya
Příspěvekod Jenya » 16 years ago
Currently this feature is supported only for Atheros Merlin chips. (ie. AR9220, AR9280, AR9223).
Currently tested models: RouterBOARD R52N and R2N only.
Dom
Příspěvekod Dom » 16 years ago
Konecne neco cim se da do toho bordelu v Praze nahlidnout :-)
