What's new in 3.16:
*) added support for IGMP proxy;
*) improved Nstreme polling in wireless-test;
*) routing-test - routing filters now use regular expressions
to match BGP AS_PATH; use '_' (underscore) to match any of:
comma, space, beginning of line, end of line, parentheses, braces;
*) make secondary disk contents visible under /file;
*) console - allow use of '/' and '.' characters in backup, export
and print output file names;
*) fixed bug - hotspot universal client did not work for clients
with IP address ending with 127 or with 224-239;
*) fixed problem - x86 clock was 10 times faster then it should be on some boards;
*) fixed kernel panic on RB1000;
*) console - fixed wrapping of long lines in GNOME Terminal;
*) console - autodetect Mac OS X Leopard Terminal.app, fixes condition
when only the bottom line of the terminal was used;
*) console - 'find' commands could not match some properties, like
'routing-mark' of the '/ip route find' command. Fixed;
Verzia 3.16
Verzia 3.16
x86 DualCore . vse ok.. nstream ok..
jen me stve ze v simple pri unlimited neukazuje prutok dat a prenastavovat ty polozky u vseho nechcu.
rkulisek píše:x86 DualCore . vse ok.. nstream ok..
udelej si na to skript
z 3.10 na 3. 16
4x RB600 - OK
1x RB433 - OK
1x x86 DualCore 2GB RAM -
z 2.9 na 3.15 - OK
z 3.15 na 3.16 - chyba:
ISDN ERROR - failed to start ISDN msg
4x RB600 - OK
1x RB433 - OK
z 2.9 na 3.15 - OK
Sem si vsimnul, ze ve winboxu pribylo nejake nove policko "Mesh" - netusi nekdo co se pod timto nazvem skryva?
Jenya píše:Sem si vsimnul, ze ve winboxu pribylo nejake nove policko "Mesh" - netusi nekdo co se pod timto nazvem skryva?
Je to tam už od verze 3.15 -
HWMP+ is a MikroTik specific layer-2 routing protocol for wireless mesh networks. It is based on Hybrid Wireless Mesh Protocol (HWMP) from IEEE 802.11s draft standard. It can be used instead of (Rapid) Spanning Tree protocols in mesh setups to ensure loop-free optimal routing.
HWMP+ mesh routing supports not only WDS interfaces, but also Ethernet interfaces inside the mesh.
So you can use simple Ethernet based distribution system, or you can combine both WDS and Ethernet links!
no a teď trochu česky protože bych řekl že ani ten co sem pastnul anglickej výklad neví co to je. http://www.marigold.cz/item/mesh-site-p ... ych-sitich
jo a jinak řečeno to je roaming + nějaký drobnosti na víc. Někdo se tu tenkrát ptal na roaming po podniku, tak tohle by mu mělo pomoct. I když mi to silně připomíná ad-hoc sítě s tim že když mám k bodům přitahnutej ethernet a ten pak spojenej s ostatními body tak to jde nejkratší cestou.
Máš pravdu, nevím k čemu to je a používat to nebudu
umim si to představit jako síť v podniku nebo nějakym skladu kde se komunikuje wifinou. Každých třeba 20m dáš apčko a pak můžeš lítat s čtečkou čárových kodů po hale. Asi je to náhrada za to že mikrotik neumí ad-hoc a timhle se to vyřeší.
- willi.coyotte
RB 333 ROS 3.0 -> 3.16 ... ok
RB 433 ROS 3.14 -> 3.16 ...ok
RB 133 ROS 3.15 -> 3.16 ...ok
jen tak pro zajímavost:
verze 3.16 je na mikrotik.com označená jako Testing
takže Litevci si z userů dělají betatestery už oficiálně
Jako stable verze se tam dá stáhnout verze 3.13
nic mezi 3.13-3.16 tam ke stažení offiko nemají...ještě aby, když je v 3.14 a 3.15 hafo chyb
v 3.16 mají balíček wireless-testing, kvůli testování nového dirveru s vylepšeným pollingem v nstreme..nic méně, kdo ví jak to zatím chodí
