Verzia 3.4
airbilly
Verzia 3.4
Příspěvekod airbilly » 17 years ago
What's new in 3.4:
*) improve transmit lockup detection to work around issues with few wireless
clients;
*) fixed bug - RB100/RB500 upgrade from RouterOS v2.9 could fail if
version 2.9 was installed by netinstall from v3;
*) console - compatibility syntax for 'find' and 'print where' expressions.
If = or != operation has as the left operand name of item property, without
leading '$', then right hand operand is parsed according to the syntax
of that propery. This also adds back command line completions. Example:
/ip address print where interface=ether1
ether1 was parsed as a reference to variable "ether1", now it is parsed as
name of the interface, like in version 2.9;
*) backup - proceed on read errors, log errors with topics "backup, critical";
*) console - allow commands like 'monitor' and '/tool fetch' in scheduler
scripts;
*) web proxy - when src-address is specified, use it for outgoing connections;
*) fixed crash in pppoe, pptp & l2tp when using ip pools with radius server;
*) added support for Option Fusion UMTS Quad-GPRS (Vodafone Globetrotter);
*) fixed VLAN on wireless not running after reboot issue;
Airbilly - MOBIL ATAK
Příspěvekod honzam » 17 years ago
RB532 funkční v poho
konvertor
Příspěvekod konvertor » 17 years ago
taky nalito,no problem na RB333
romanmarik2
Příspěvekod romanmarik2 » 17 years ago
Tak už 10 minut běží bez problémů ovis verze 1 :-) problém s kousání starších ovisů je asi vyřešen...
Benny
Příspěvekod Benny » 17 years ago
RB600 v pohode
berkoff
Příspěvekod berkoff » 17 years ago
RB333 - 3 kusy, bez problemu vcetne upgrade pres web
Berkoff
haklina
Příspěvekod haklina » 17 years ago
tak ted se hodlam vyměnit rb333 az ovislnka s appro na kterej je napojenejch asi 30 ovisů 5450 a 5460 ze starým firmavarem, tak bud bude od toho sekani na vzdy klid a nebo se z toho po...
Polk
Příspěvekod Polk » 17 years ago
RB133 a RB532 ok.
haklina
zatim to vse facha takze to vypada OK.
aladinus
Příspěvekod aladinus » 17 years ago
po upgradu x86 verze na CF v ide redukci na desce Supermicro P8SCT to mikrotik už nerozdýchal. při bootu zkončí na Loading...
Na verzi 3.3 jela ok.
schneiderf
Příspěvekod schneiderf » 17 years ago
Na 3.3 mi tuhnul WRAP 1x denně, po nahrátí 3.4 jede zatím OK. Zatím 2.5 dne :)
belmorfeus
Příspěvekod belmorfeus » 17 years ago
po upgradu z 2.9.47 na 3.4 mikrotik nerozdychal taky (X86 stroj). Byl tam M1 modul s L4 licenci, musel jsem urychlene vymenit za jiny modul protoze se jednalo o centralni server.
klapik
Příspěvekod klapik » 17 years ago
Přestalo mi fungovat routovaní.... (RB600) :( Nizsi verze jedou, bez problemu.
...jsem nejvetsi lama na svete....
klapik píše:Přestalo mi fungovat routovaní.... (RB600) :( Nizsi verze jedou, bez problemu.
routování na RB600 s 3.4 normálně valí. Problém hledej jinde...
Příspěvekod net.work » 17 years ago
setkavam se s problemem downgradu zpatky na v.2.9 z teto v3.4... postup - nahraju na ftp soubory a pres web rozhrani dam down/up grade... rb se rebootne a nic.. v logu nic... jedna se o rb133.. neznate nejaky funkcni zpusob downgradeu?
dik za odpovedi
Jan Ptáček
