Verze 3.3
fra.iesus
Verze 3.3
Příspěvekod fra.iesus » 17 years ago
What's new in 3.3:
*) fixed bug - PPPoE server could crash when running on multiple cores;
*) fixed bug - bridging over PPP interfaces with encryption enabled did not work;
*) fixed dhcp server - arp entries were not added after reboot;
*) fixed problem in pppoe, pptp & l2tp - server could restart;
*) fixed bug in console - bridge and ip filter "print static" and "print
dynamic" commands had the opposite effect;
*) fixed bug - DHCP server did not parse Relay-Agent-Info option 82;
*) fixed bug - hotspot login could fail with "ippool acquire failed";
*) graphing - ip address formatting bugfix;
*) ospf - added support for Opaque LSA;
*) ospf - fixed routes changing type from Intra Area to AS External;
*) ospf - fixed multicast group membership in case there are
multiple IP networks configured on a single interface;
*) routing - now iBGP routes are resolved through IGP and static by default;
*) user manager - fixed ampersand bug;
*) updated regulatory information for Australia;
*) updated drivers;
*) updated drivers;
- tak na tohle jsem zvedavy (rb600 nam delala to, ze po nejake dobe prestal fungovat clovicek na ethernetu)
haklina
Příspěvekod haklina » 17 years ago
Hlavně zkusit kousání 5450tek
fra.iesus
haklina píše:Hlavně zkusit kousání 5450tek
zkusit a kdyby se kousaly tak POSLAT SUPOUT.RIF - dokud se nikdo o problemu nedozvi, tak ho nema jak resit (jeste presneji nema CO resit) ;)
cin
Příspěvekod cin » 17 years ago
Nasadene na 12 shaperoch a vsetko slape ako ma.
Příspěvekod net.work » 17 years ago
jsou v teto verzi obsazene nove drivery pro atheros karty? jestli jo, jde to nejak poznat?
Jan Ptáček
Radek Úlehla
Příspěvekod Radek Úlehla » 17 years ago
od verze 3.2 se už ovislinky nesekaj :o)
DRAKK
Příspěvekod DRAKK » 17 years ago
Mne se na RB333 s v 3.2 sekal Ovis5460 s puvodnim fw... :(
******WWW.DRAKKNET.CZ******
haklina
mě taky,
haklina
a ještě nfunguje ze zařízením WAP354 zabezpečení wpa-psk aes, na tkip to jde ale to vytěžje moc procáku.
Besito
Příspěvekod Besito » 17 years ago
fra.iesus píše:
Bylo by dobré někam napsat jak zjistit chybu a co všechno se má k chybě připsat (např: konfigurace, hardware a pod)... je spousta lidí (vč. mě), kteří by rádi poslali, ale neví jak a a ni kam...
Jinak tahle verze mi zatim slape... ale většinou se mi stává, že když sem napíšu, že funguje, tak mi do pár minut něco klekne...
novajz
Příspěvekod novajz » 17 years ago
Hele, lidi, vy tu furt resite nejake sekani ovisu. Me se taky sekaly. Bylo to tak, že když jsem si pingal na ovise, tak bylo vse OK, ale jakmile jsem se spojil, bylo po něm a nepingl jsem si vubec nikde. Pomohl az reboot ale jakmile se spojil, proslo cca 10paketů a zase to samé. Jestli tohle je to sekání co máte na mysli, tak aspon u mě to verzí MT nebylo. A už se mi nesekaj a jedou všechny OK
Novajz
Zelenáč, ale snažím se, je to moje hobby
jirk
Příspěvekod jirk » 17 years ago
Zdarec Ty nás napínáš. Čím jsi to vyřešil?
novajz
Si děláte kozy, ne??? Jestli je to co jsem popsal to vaše sekání ovisů, tak já jsem srandokaps pro romské spoluobčany. Ku... lidi, nedelejte si prdel. Já jsem normální amatér a vůbec netuším jak ta naše sít vlastně funguje. Ted vážně, fakt je to co jsem popsal to sekání ovislinků 5460 ???????????????
Novajz
haklina
jo tak nejak jak si to psal0, např. 2 roky v v kuse běží ovis bez problému, občas vytuhne cca 5x za rok, pokud se připojí na AP s v 3.xx tak po cca 10ti vteřinách vytuhne a to třeba 10x za sebou, pokud se připojí na verzi 2.xx tak jde v pohode, vzhedem k tomu že mi to dělá na několika AP a i někomu tak na tom asi něco pravdy bude. V praxy je to tak ze kdys misto V2 nasadim V3 tak na 99procent mam vystarano na celej den objizdeni klientu a prehravani u kazdyho firmwaru.
novajz
Omlouvám se Všem za šíření poplašné zprávy, špatně jsem pochopil váš problém. Jen prosím moc nekamenovat, mám dneska svůj den blbec.
Novajz
