Toto je původní verze serveru ISPforum.cz do února 2020 se zachovaným plným přístupem a možností registrace nových uživatelů. Aktivní verzi fóra naleznete na adrese https://telekomunikace.cz
8.7.0
vecino
Příspěvekod vecino » 3 years ago
jakduch
Příspěvekod jakduch » 3 years ago
v8.7.0 (XC, WA, 2XC, 2WA) / February 4, 2020
Major changes:
* PTP performance improvements and reduced CPU load on higher channel widths.
Up to 40% improvement for pure PTP 80MHz bridge.
For max performance enable PTP bridge mode, make sure VLANs & bridge firewall aren't used and leave MTU at default 1500 bytes.
* Simplify airMAX mode configuration: airMAX AC-only mode fully replaced with airMAX mixed mode.
* Introduce flex-new 10MHz option (beta).
* Improve device stability when handling huge amounts of connections.
* Faster scan when auto channel width option is enabled on station.
* DFS prescan feature on access points. It utilizes the secondary radio for DFS
detection. DFS prescan is automatically started on system boot after
management radio timeout. It runs for 10-30 minutes and waits for CAC
(Channel Availability Check) time on each DFS channel. Frequencies where no
radar events are detected during the CAC wait are marked in the wireless
settings frequency list. This iteration of the DFS prescan feature is
informational only - device does not act on the collected information yet.
Known issues:
* WebUI: Due to PTP performance optimizations LAST IP column in the station list shows "unknown" for airMAX M clients. Will be fixed with the next airMAX M release.
Regulatory updates:
* DFS algorithm improvements.
* Update frequency plan for Indonesia according to PM 1-2019: removed 2474MHz.
* Update frequency plan for Kenya.
Security Fixes:
* Dnsmasq patched for CVE-2019-14513
Fixes:
* Connectivity: Disable scan list if it is configured with invalid frequencies.
* Connectivity: Fix issue where AP can stop receiving traffic when antenna gain is changed.
* Connectivity: Fix site survey when radio is configured for the "Licensed" country.
* Connectivity: When auto channel width is enabled, station could connect to AP with lower channel width (for example 20MHz instead of 40MHz).
* System: Also block access via IPv6 when block management access is enabled.
* System: Fix GPS time sync - the GPS chip had a week counter rollover bug.
* System: Fix for fast network reconfiguration. Addresses are not fully flushed from old interface when using DHCP client and adding VLANs.
* System: Improve 2AC stability on system boot with many stations.
* System: Optimize airView spectral daemon memory use.
* System: Remove DynDNS.
* System: Remove MAC-Telnet.
* System: Send a single beacon packet every 30s when disconnected from controller.
* System: Update self-signed HTTPS certificate generation rules to match macOS v10.15 and iOS v13 requirements.
* WebUI: Add warning notification if frequency scan list contains only DFS channels.
* WebUI: Collapsable Wireless Advanced section.
* WebUI: Easier to select target AP in the site survey tool.
* WebUI: Fix for empty discovery tool dialog when device name contains invalid characters.
* WebUI: Fix for missing second Ethernet port information in dashboard details for dual port devices.
* WebUI: Fix for page load issues when accessed over slow connections.
* WebUI: Fix warning when invalid firmware version is uploaded.
* WebUI: Improve "Management radio is enabled" warning - it is now less persistent and more informative.
* WebUI: Improve PTMP throughput charts in dashboard: AP side shows total AP throughput, STA side is split into separate RX/TX charts.
* WebUI: Improve firmware update checking.
* WebUI: Make the DFS wait bar more visible.
* WebUI: Merge auto channel width and manual channel width fields on station.
* WebUI: Move traffic shaping section from advanced to simple network settings page.
* WebUI: Show a notification while support file download is in progress.
* WebUI: Show remote airView spectral data even if local airView is disabled.
svestka
Příspěvekod svestka » 3 years ago
Už jste to někdo riskl?
Lepší než výhra ve Sportce :)
vecino
https://community.ui.com/releases/airMAX-AC-Firmware-v8-7-0/2f500636-33f7-4134-aad2-df3ddcf1a9e6?page=2
Known issues
We are investigating UNMS connectivity issues that are related to name server selection. Make sure configured name servers are reachable.
Mám to na ISO Station 5AC, PrismStation 5AC a LiteBeam 5AC Gen2 a nevím o tom.
jahpisin
Příspěvekod jahpisin » 3 years ago
jojo na par kousků jsem to poslal, zatím se nic nědeje,čistě AC zařízení.
ale pořád nechápu proč nejsou vyřešeny některé základní věci, který mě vytáčí již dlouho.
1. nemožnost mít aspoň 2x watchdog
2. umístění reboot/reset hned vedle sebe (naštěstí jsem se ještě neukliknul, ale párkrát se to málem již stalo,když potřeboval reboot, a ja se bavil zároveň s kolegy a málem se při tom ukliknul :) )
3. problém občas se nalogovat do zařízení, prostě jen vyplivne zpátky login
4. nemožnost si hodit okno sitesurvey bokem tak jako to bylo běžné u M z toho šílím poslední dobou asi nejvíc.
pedro4444
Příspěvekod pedro4444 » 3 years ago
jj zatial pohoda
Mr.Seaman
Příspěvekod Mr.Seaman » 3 years ago
Bude jsem slepej nebo to vyhodili, ale kdyz nahraju tenhle FW tak na Prism rocket gen2 bez konfigurace a pak konfiguruju jako AP PtMP , nejde nastavit wireless mode - rovnou to da AirMAX mixed - trosku blby, kdyz vim, ze na klientech mam jen AC...
cerva
Příspěvekod cerva » 3 years ago
Mr.Seaman píše:Bude jsem slepej nebo to vyhodili, ale kdyz nahraju tenhle FW tak na Prism rocket gen2 bez konfigurace a pak konfiguruju jako AP PtMP , nejde nastavit wireless mode - rovnou to da AirMAX mixed - trosku blby, kdyz vim, ze na klientech mam jen AC...
To není bug, to je fíčura:
wwire
Příspěvekod wwire » 3 years ago
cerva píše:
On taky ten AC mode za moc nestál. Buď fixed tdd a nebo mixed.
wifi-pc
Příspěvekod wifi-pc » 3 years ago
Ahoj, nejak nechapu, kde mohu nastavit zpetnou kompatibilitu s airmax M5 (mixed) a kde zapnout jen AC. Poradite diky
DarkLogic
Příspěvekod DarkLogic » 3 years ago
Cetl jsi release notes? Tuto volbu uz nemas. Je jediny rezim spolecny pro AC i M5.
wifi-pc
DarkLogic píše:Cetl jsi release notes? Tuto volbu uz nemas. Je jediny rezim spolecny pro AC i M5.
jasne, ze cetl. * Zjednodušení konfigurace režimu airMAX: režim pouze pro AC airMAX plně nahrazen smíšeným režimem airMAX.
DarkLogic
Tak vidis :)
Zpět na „Verze“
Kdo je online
Uživatelé prohlížející si toto fórum: Žádní registrovaní uživatelé a 2 hosti
