Verze 6.46.1
Verze 6.46.1
What's new in 6.46.1 (2019-Dec-13 12:44):
*) capsman - fixed CAP upgrading (introduced in v6.46);
*) console - fixed "clear-history" restoring historic actions after power cycle;
*) console - removed "edit" and "set" actions from "System/History" menu;
*) defconf - fixed default configuration loading after fresh install (introduced in v6.46);
*) dhcpv6-server - use lease time from RADIUS;
*) dude - fixed image and font file accessing (introduced in v6.46);
*) gps - only adjust system time after GPS signal is established;
*) health - fixed health reporting on OmniTIK 5 PoE ac;
*) ipsec - improved system stability when processing decrypted packet on unregistered interface;
*) l2tp - improved system stability when disconnecting many clients at once;
*) log - fixed "disk-file-name" parameter validation (introduced in v6.46);
*) lora - added support for MIPSBE, PPC, TILE and x86 architectures;
*) lora - improved confirmed downlink forwarding;
*) lte - do not reset modem when setting the same SIM slot on LtAP;
*) lte - show SIM error when no card is present;
*) ppp - fixed session establishment with high amount of tunnels (introduced in v6.46);
*) ppp - prioritize "remote-ipv6-prefix-pool" from PPP secret over PPP profile;
*) qsfp - do not show "sfp-wavelength" for cables that do not support it;
*) snmp - fixed health related OID polling (introduced in v6.46);
*) supout - fixed autosupout.rif file generation (introduced in v6.46);
*) system - fixed "*.auto.rsc" file execution (introduced in v6.46);
*) user-manager - fixed "db-path" parameter validation (introduced in v6.46);
*) webfig - fixed skin folder presence (introduced in v6.46);
*) winbox - fixed "allowed-number" parameter setting invalid value in "Tool/SMS" menu;
*) winbox - show "LCD" menu only on boards that have LCD screen;
*) wireless - added "russia4" regulatory domain information;
*) wireless - improved compatibility by adding default installation mode and gain for devices with integrated antennas;
*) wireless - improved compatibility for Switzerland wireless country profile to improve compliance with ETSI regulations;
