Zdravim Vas. Heh necakal som ze budem mat s tymto mojim hap ac2 viac "starosti" ako s mojim povodnym mikrotikom.
No ku mojmu dlasiemu problemu. Ked sa chcem pripojit na 5GHz siete tak sa nedokazem cez notebook w10. dostanem sa ku hlaske ze nieje moz e sa pripojit. Heslo davam spravne. Na MT telefone mi 5GHz siet neukazuje aj ked ju mobilne zariadenie podporuje.
Wifi som si nastavil tak ako na mojom predchadzajucom mikrotiku.
Dakujem.
Problem s 5GHz
Fester182
Fester182
Co treba este uviest? Ako vravim va mojom starom mikrotik som mal nastavene takto a vsetko fungovalo. Dakujem
S_a_M
Vijed konfigurak pres terminal zadej:
export compact file=zaloha.txt
a pak sen postni nastaveni obledne 5gcka posledni dobou maji w10 problem se zabezpeceni a protokolem wpa2 a 802.11 pomuze
bohuzel natavujes pres klikatko takze jsi dost omezenej...
Fester182
nech sa paci.
# dec/14/2019 22:06:52 by RouterOS 6.46
# software id = EFQG-GN6A
# model = RBD52G-5HacD2HnD
# serial number = zmazane
/interface bridge
add admin-mac= zmazane auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=3 band=2ghz-b/g/n channel-width=\
20/40mhz-XX country=slovakia disabled=no distance=indoors frequency=auto \
frequency-mode=regulatory-domain installation=indoor mode=ap-bridge ssid=\
ReBl wireless-protocol=802.11
set [ find default-name=wlan2 ] antenna-gain=3 band=5ghz-a/n/ac \
channel-width=20/40/80mhz-XXXX country=slovakia disabled=no distance=\
indoors frequency=auto frequency-mode=regulatory-domain installation=\
indoor mode=ap-bridge ssid=ReBl_5GHz wireless-protocol=802.11
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=Blanarik \
wpa2-pre-shared-key=Blanarik
/ip pool
add name=dhcp ranges=192.168.88.10-192.168.88.254
/ip dhcp-server
add address-pool=dhcp disabled=no interface=bridge name=defconf
/interface bridge port
add bridge=bridge comment=defconf interface=ether2
add bridge=bridge comment=defconf interface=ether3
add bridge=bridge comment=defconf interface=ether4
add bridge=bridge comment=defconf interface=ether5
add bridge=bridge comment=defconf interface=wlan1
add bridge=bridge comment=defconf interface=wlan2
/ip neighbor discovery-settings
set discover-interface-list=LAN
/interface detect-internet
set detect-interface-list=all
/interface list member
add comment=defconf interface=bridge list=LAN
add comment=defconf interface=ether1 list=WAN
/ip address
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server network
add address=192.168.88.0/24 comment=defconf gateway=192.168.88.1
/ip dns
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan
/ip firewall filter
add action=accept chain=input comment=\
"defconf: accept established,related,untracked" connection-state=\
add action=drop chain=input comment="defconf: drop invalid" connection-state=\
invalid
add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
"defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" \
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy" \
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" \
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" \
connection-state=established,related
add action=accept chain=forward comment=\
"defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop invalid" \
connection-state=invalid
add action=drop chain=forward comment=\
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
connection-state=new in-interface-list=WAN
/ip firewall nat
add action=masquerade chain=srcnat comment="defconf: masquerade" \
ipsec-policy=out,none out-interface-list=WAN
/system clock
set time-zone-name=Europe/Bratislava
/tool mac-server
set allowed-interface-list=LAN
/tool mac-server mac-winbox
Fester182
S_a_M
Fester182
Nastavene je a uz na W10 mi kazde zariadenie na 5GHz siet pripojilo. Dakujem.
Chcel by som sa spytat z akeho dovodu bolo potrebne nastavit hodnotu 5200. dakujem za vas cas .
S_a_M
Tak prvne evidentne wokynka maji problem s autofrekvenci mikrotiku 5200 mne napadla jako prvni kdyz jsem to psal
nic jineho v tom nehledej je to standardni frekvence indooru. Automat pouzivam jen u capsmana a to kvuli reselectu pac docela dobre funguje
Sidi
Fester182 píše:Nastavene je a uz na W10 mi kazde zariadenie na 5GHz siet pripojilo. Dakujem.
Ještě bych z "regulatory domain" přeladil na "superchannel". Může se stát, že MK zadetekuje falešně radar, přeladí na nesmyslnou frekvenci a zase nepůjde připojení.
Fester182
Dakujem obom za vysvetlenie... vidim ze aj ked mikrotik pouzivam nejaky ten piatok tak mam stale nedostatky ...
V pripade ked ale prehodim na super chanel tak ma upozorni hlaska ze v krajine slovakia to zial nieje mozne.
- Snímka obrazovky z 2019-12-16 14-36-18.png (10.71 KiB) Zobrazeno 8907 x
pepulis
Fester182 píše:Dakujem obom za vysvetlenie... vidim ze aj ked mikrotik pouzivam nejaky ten piatok tak mam stale nedostatky ...
No country + superchanel.
Daxxim
pepulis píše:Fester182 píše:Dakujem obom za vysvetlenie... vidim ze aj ked mikrotik pouzivam nejaky ten piatok tak mam stale nedostatky ...
Debug + Superchannel
Fester182
Pani dakujem obom, je v tom nejaky rozdiel debug a nocountry ? no funguju obe
S_a_M
Nechci vam do toho kecat kuci ale je to hap ac 2 neni uplne jedno co tam da za region treba ugandu hlavne musi sedet frekvencne pro cz
dalsi vec je urcite na domacim rtr nepouzivat superchanel radeji region s manualtxpower obcas maji nejkera zarizeni se superchanelem problem to je jen osobni zkusenost. Takze si kameny uklidte do mosnicek...
