What's new in 6.45.7 (2019-Oct-24 08:44):
MAJOR CHANGES IN v6.45.7:
!) lora - added support for LoRaWAN low-power wide-area network technology for MIPSBE, MMIPS and ARM;
!) package - accept only packages with original filenames (CVE-2019-3976);
!) package - improved package signature verification (CVE-2019-3977);
!) security - fixed improper handling of DNS responses (CVE-2019-3978, CVE-2019-3979);
Changes in this release:
*) capsman - fixed frequency setting requiring multiple frequencies;
*) capsman - fixed newline character missing on some logging messages;
*) conntrack - properly start manually enabled connection tracking;
*) crs312 - fixed combo SFP port toggling (introduced in v6.44.5);
*) crs3xx - correctly display link rate when 10/100/1000BASE-T SFP modules are used in SFP+ interfaces;
*) crs3xx - fixed management access when using switch rule "new-vlan-priority" property;
*) export - fixed "bootp-support" parameter export;
*) ike2 - fixed phase 1 rekeying (introduced in v6.45);
*) led - fixed default LED configuration for RBLHG5nD;
*) lte - fixed modem not receiving IP configuration when roaming (introduced in v6.45);
*) radius - fixed open socket leak when invalid packet is received (introduced in v6.44);
*) sfp - fixed "sfp-rx-power" value for some transceivers;
*) snmp - improved reliability on SNMP service packet validation;
*) system - improved system stability for devices with AR9342 SoC;
*) winbox - show SFP tab for QSFP interfaces;
*) wireless - added "canada2" regulatory domain information;
*) wireless - improved stability when setting fixed primary and secondary channels on RB4011iGS+5HacQ2HnD-IN;
Verze 6.45.7
- honza198
u nas OK: SXT,LHG,1200-DUDE-ED,CCR1016,911,912,922,OmniTik,Dyna,CRS,800 aj zatim no-problema
emel
1x RBD52G-5HacD2HnD - po upgrade jsem zaregistroval několik link up/down na jediném eth. portu, který na tom mám aktivní. Netvrdím, že to souvisí s aktualizací, ale dříve jsem si toho nevšiml.
1x RB4011iGS+ - zatím OK
1x RB931-2nD - zatím OK
Ondrej1
shooter
- DRAKK
Tak u dvou Dyna (jedna koupena dnes s RoS 6.42.12) po upgrade na 6.45.7 umrela. Doma pripojena a cekala na Netinstall....ten pomohl..ale musel jsem to sundat ze sajtu.
S_a_M
phodny
zdá se mi, že v této verzi je tlačítko [Reset configuration] smrtící. Už potřetí se mi stalo, že jsem nový kus upgradoval na 6.45.7, poté resetoval konfiguraci, abych si to nastavil do čistého po svém a winbox nenaběhl. Pomohl netinstall s verzí 6.44.
Stalo se mi to na cAP lite(1x) a RB951Ui-2nD(2x)
