Ubiquiti PBE-M5-400 AirOS v6.2.0 (XW)
joker
Příspěvekod joker » 6 years ago
Nedari se mi to nastavit do rezimu AP, co delam spatne?
Jaky kanal a jakou sirku pasma mam nastavit, abych AP videl v iPadu?
Webove rozhraní a rozhrani te mobilni aplikace se ponekud lisi ale zkousel jsem snad vsechno, i factory reset, jako Station OK, ale jako AP ho nevidim :-(
komenski
Příspěvekod komenski » 6 years ago
Předně musíš vypnout Airmax - první záložka s logem UBNT...
joker
Jenze tim to neni. Airmax zabranuje pripojeni, nikoliv viditelnosti (na iPadu).
Co jsem zjistil:
Firmware 6.1.9 jeste jde spustit AP
Firmware 6.1.11 a vyssi uz nejde spustit AP
Problem trosku je, ze jsem APcko nevidel ani z jineho AirOS (XW), nejen z iPadu 2019 (posledni iOS), takze nejspise vubec nenabehne? Bug nebo feature?
To dela jenom mne? Ze si toho nikdo nevsim? Mam freq: Auto
6.1.11 (XM/XW/TI) Changelog / Mar 29, 2019
Regulatory updates:
- DFS algorithm improvements
- Updated UNII-3 frequency list for Germany to support 40MHz channel width (5755-5870MHz)
- Extended frequency list for Czech Republic according to the ETSI EN 301 893 standard ???
- Fix: Security fix for UBNT Discovery: TCP scan on 10001 port could cause 100% CPU use
- WEB UI: Frequency List improvements for Licensed mode: added frequency highlighting by country
6.1.9 (XM/XW/TI) Changelog / Jan 11, 2019
- airMAX-ac FF: Improved station connection
- airMAX-ac FF: Wrong operation when aggregation is disabled
Licensed firmwares updates:
- Added Licensed selection in country list for WORLD version products
- Added Canada (Licensed) selection in country list
Regulatory:
- Update channel plan for India according to the new regulation valid from 01/01/2019
Improvements:
- WDS improvements for XM devices
- airOS stability improvements
- UNMS agent upgrade to v0.5.2
- Update dropbear to v2018.76
Fixes:
- Fix: Reduce DFS false positive events
- Fix: Return back Maximum TX Data Rate selection of MCS 0, MSC 1 for 1x1 and 2x2 devices and MCS 8, MCS 9 for 2x2 devices
- Fix: Set CPU speed to 400MHz for M900 devices
- Fix: Sometimes traffic may stop when WDS is disabled
- Fix: M900 issues (possible fix)
WEB UI:
- WEB UI: Fix GMT (Western Europe Time) and add British Time Zone
Příspěvekod Peyrak » 6 years ago
A cekal jsi dostatecne dlouho, aby to zacalo vysilat? Nekdy to trva i 15 minut.
joker
Cekal jsem az doted = 6 hodin :-)
Pomuze ale
1) downgrade z vyssiho na AirOS 6.1.9 anebo
2) reset + nastavit to jako Argentinu resp. jiny nez CZ, protoze ve vyssim FW nez 6.1.9 je: Extended frequency list for Czech Republic according to the ETSI EN 301 893 standard - tim si to vysvetluji, ze by mohlo mit vliv...?
Pro poradek uvadim, ze jsem to nastavoval a upgradoval pres https://apps.apple.com/cz/app/unms-mobi ... 22489?l=cs
Mate nekdo Powerbeam M5 s AirOS 6.2.0 (aktualni FW) v CZ nastaveni a v rezimu AP PtMP? Vysila?!
Napiste, co si o tom myslite... Jestli je to mozny nebo mam vadny 2 kusy nebo levy ruce? Rad bych tomu prisel na kobylku. Zrejme se to da poresit pres SSH, nejakym prikazem?
Ps: Mám tu PBE-M5-400 a PBE-M5-300, je to zrejme stejne zelezo a chova se mi to myslim uplne stejne.
joker
Nikdo nevi?!
