Hotspot
nastrel
Hotspot
Příspěvekod nastrel » 7 years ago
Hojte vsichni, nastavuji na Mikrotiku hotspot a mam problem s presmerovani na logovaci stranku. Hotspot mam na wifi rozhrani. Prihlaseni k wifi probehne a nasledne si spustim webovy prohlizec kde zadam napr. google.com nebo cokoliv a vysledek - stranka nenalezena. Kdyz zadam rucne domenu nebo ip adresu MK pak se mi zobrazi prohlasovaci stranka a dale uz vsechno funguje. Otazka je proc se automaticke nepresmeruje pri nacitani stranky na logovaci stranku.
/interface bridge
add admin-mac=74:4D:28:5A:A0:2A auto-mac=no comment=defconf name=bridge
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=prdelOO9 supplicant-identity=\
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto installation=indoor \
    mac-address=84:4D:28:5A:A0:2E mode=ap-bridge security-profile=prdelOO9 ssid=MK wireless-protocol=802.11 wps-mode=disabled
/ip hotspot profile
add dns-name=test.local hotspot-address=172.16.5.1 login-by=http-chap name=hsprof1
/ip pool
add name=default-dhcp ranges=192.168.88.10-192.168.88.254
add name=hs-pool-1 ranges=172.16.5.2-172.16.5.254
/ip dhcp-server
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=hs-pool-1 disabled=no interface=wlan1 lease-time=1h name=dhcp1
/ip hotspot
add address-pool=hs-pool-1 addresses-per-mac=1 disabled=no interface=wlan1 name=hotspot1 profile=hsprof1
/ip hotspot user profile
add add-mac-cookie=no address-pool=hs-pool-1 !mac-cookie-timeout name=Muj rate-limit=10M/2M shared-users=10 transparent-proxy=yes
/interface bridge port
add bridge=bridge comment=defconf interface=ether2
add bridge=bridge comment=defconf interface=ether3
add bridge=bridge comment=defconf interface=ether4
add bridge=bridge comment=defconf interface=pwr-line1
/ip firewall connection tracking
set enabled=yes tcp-established-timeout=5m
/ip neighbor discovery-settings
set discover-interface-list=LAN
/interface list member
add comment=defconf interface=bridge list=LAN
add comment=defconf interface=ether1 list=WAN
/ip address
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=172.16.5.1/24 interface=wlan1 network=172.16.5.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
/ip dhcp-server network
add address=172.16.5.0/24 comment="hotspot network" gateway=172.16.5.1
add address=192.168.88.0/24 comment=defconf gateway=192.168.88.1
/ip dns
set allow-remote-requests=yes servers=1.1.1.1
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan
/ip firewall filter
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
/ip firewall nat
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface-list=WAN
add action=masquerade chain=srcnat comment="masquerade hotspot network" src-address=172.16.5.0/24
/ip hotspot user
add name=admin
add name=testmk profile=Muj server=hotspot1
/system clock
set time-zone-name=Europe/Prague
/tool mac-server
set allowed-interface-list=LAN
/tool mac-server mac-winbox
reset
Příspěvekod reset » 7 years ago
nezkoumal jsem ten tvuj skriptik, ale problem je se SSL v pripade presmerovani
zkus to ciste na http
nastrel
Ne bohuzel ani http nejde. Musim proste rucne zadat url adresu Mikrotiku. No nevim nedavno co jsem nastavoval na unifi slo vsechno na prvni dobrou.
Noxus28
Příspěvekod Noxus28 » 7 years ago
Ja by som asi v user profiles skúsil vypnúť transparent proxy.
nastrel
Zkusil jsem reset mikrotiku do tovarniho nastaveni. Chci rozjet jen trial ucet. Zkusil jsem s volbou transparent proxy i bez ni. Bohuzel bez vysledku.
/interface bridge
/interface wireless
    mode=ap-bridge ssid=MikroTik-5AA02E wireless-protocol=802.11
/interface list
/ip hotspot profile
add dns-name=t.cz hotspot-address=192.168.87.1 login-by=http-pap,trial,mac-cookie name=hsprof1 rate-limit=5M/5M trial-uptime-limit=5m \
    trial-uptime-reset=10m
set [ find default=yes ] shared-users=10
/ip pool
add name=hs-pool-1 ranges=192.168.87.2-192.168.87.254
/ip dhcp-server
/ip hotspot
add address-pool=hs-pool-1 disabled=no interface=wlan1 name=hotspot1 profile=hsprof1
/ip settings
set allow-fast-path=no
/ip address
add address=192.168.87.1/24 comment=defconf interface=wlan1 network=192.168.87.0
/ip dhcp-client
add address=192.168.87.0/24 comment="hotspot network" gateway=192.168.87.1
/ip dns
/ip dns static
/ip firewall filter
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" ipsec-policy=out,ipsec
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
    in-interface-list=WAN
/ip firewall nat
add action=masquerade chain=srcnat comment="masquerade hotspot network" src-address=192.168.87.0/24
/ip hotspot user
add name=admin
/ip service
set www-ssl disabled=no
/system clock
/tool mac-server
Co jsem vysledoval ve firewallu tak by melo dojit k presmerovani na port 64874. Provedl jsem scan portu mikrotiku a skutecne nmap port oznaci za otevreny. Ovsem stranka se nezobrazi.
