Verze 3.0rc9
aj_rade
Verze 3.0rc9
Příspěvekod aj_rade » 18 years ago
Jdeme rychle do finale zda se :)
What's new in 3.0rc9:
*) fix for rb100 - can change ethernet settings when interface in bridge/bond;
*) fixed problem - RouterOS did not boot on some routers
(reported disk not found);
*) fixed dns resolver - sometimes could not parse packets with AAAA records;
*) hide ppp interface & wireless passwords and keys in WinBox as well;
*) fixed traffic-flow - could hang multi cpu router and ignore targets sometimes;
*) fixed rb100 - ethernets could be set at random bandwidth limit after reboot;
*) console:
repaint whole screen after terminal size change while in editor
(same as pressing F5 or Ctrl-L). this solves numerous issues with
terminal resizing;
added more workarounds for the case when terminal is too narrow
(<4 characters);
now logical operators '&&' and '||' can also be written as 'and' and 'or';
removed 'where' and 'from' arguments of find command. now find command
can be followed by arbitrary expression that can use item properties,
e.g. "find dst-address in 192.168.0.0/16 and interface=wlan1";
added 'where' argument to print command. "print where <expr>" and
"print from=[find <expr>]" are equal;
removed filters from firewall print commands, now write, e.g.,
"/ip firewall filter print where !dynamic" instead of
"/ip firewall filter print static";
*) web proxy: fixed crash on stopping proxy;
admin sítě PLnet
Příspěvekod honzam » 18 years ago
Obligátní otázka - Kdo to testne? :D
Polk
Příspěvekod Polk » 18 years ago
koukám, že upravovali dost věcí pro RB1xx
aj_rade
Polk píše:koukám, že upravovali dost věcí pro RB1xx
jj, ja tu rc7 cpal na rb153 a vubec pak nenaskocil. Tak pak uz jedine netinstall a seriakem sem tam nacpal 2.9.38.Uz se mi to ale moc zkouset nechce znovu..
admin sítě PLnet
Mickey
Příspěvekod Mickey » 18 years ago
Jo kdyby to slo z mikrotiku stahnout, tak to i testnu...
Mickey
PS - Tak je to tam. Na RB333 a zda se, ze to slape ;-)
Mickey píše:Jo kdyby to slo z mikrotiku stahnout, tak to i testnu...
Mickey
Stáhnout už to jde, tak to testni 8)
Mickey
honzam píše:
Mickey
Jsem psal, ze uz to tam je :-)
Jedu pres to, zatim zadnej problem.
Mickey
mám to na RB333 a nemůžu se na to připojit na 5Ghz :) šit
jumbocb
Příspěvekod jumbocb » 18 years ago
honzam píše:Obligátní otázka - Kdo to testne? :D
Testnuto na 2x RB 532 a update proběhl bez problémů a jede v pohodě je pravda že je to linka na cca 100m ale no problem :D
bena
Příspěvekod bena » 18 years ago
jumbocb píše:
to musi nekdo testnout na 133 minule verze vytezovaly procesor a dokonce se casto sam restartoval
Admin komunitni site Chrastany-Net
Leeonek píše:mám to na RB333 a nemůžu se na to připojit na 5Ghz :) šit
Tak už to valí, chvilka bádání a znova zadaný security profil a je to ok, uvidíme jak na tom bude se stabilitou. Chci po něm jen routin a AP mód na CM9, tak to snad není tak :)
Blurcak
Příspěvekod Blurcak » 18 years ago
Leeonek píše:
Nabádám tě badately probádej jestli to pojede i na RB133
Besito
Příspěvekod Besito » 18 years ago
Čau, tak jsem to testnul na PC a RB532A :-)
Zatim to jede bez většich problémů, možná je prob v OSPF, ale to je asi mezi židlí a klávesnicí umě :-)
Blurcak píše:
Leeonek píše:
a taky 133C. To by mě zajímalo ještě víc :)
Blurcak píše:Nabádám tě badately probádej jestli to pojede i na RB133
Nemám žádný důvod proč cpat RC verze na zařízení kde funguje perfektně stable 2.9.38, nejsu blázen ;)
