Verze 3.0rc8
Polk
Verze 3.0rc8
Příspěvekod Polk » 18 years ago
What's new in 3.0rc8:
*) fixed problem - console did not accept ip address ranges correctly;
*) user manager - fixed problem with accounting creating too many sessions;
*) console:
added ip-prefix and ip6-prefix datatypes, written in address/mask
notation;
INCOMPATIBLE CHANGE: expressions of the form "(123/45)" (where first
operand is literal unquoted value) currently will be parsed as single
string, to write division put space before '/' (like with '.' operator);
added operator 'in' that checks if first argument is inside second
argument, currenty implemented for the case where second argument is
ip-prefix or ip6-prefix and first argument is either address or
another prefix;
don't perform full reset of terminal on login;
fixed terminal capability detection, now windows telnet client
works better. TERM environment variable is ignored completely now,
it was overriding detected values before;
*) added support for Huawei E220 USB modem;
Příspěvekod honzam » 18 years ago
To je fofr. Teï to roste jak houby po dešti :) Kdo to testne první?
Spreamer
Příspěvekod Spreamer » 18 years ago
Mám jej nahozený na rb333, který chci dát do ostrého provozu. Jediné co se mi nezdá je to, že občas problikne CPU na 100 %, ale nevím, jestli to jen špatně ukazuje nebo je fakt někde problém.
bob
Příspěvekod bob » 18 years ago
nasadene na dvoch PC routroch zda sa vsetko ok uptime 23h
0taz0
Příspěvekod 0taz0 » 18 years ago
Nemuzete to nekdo nekam nahodit , mikrotik.com je jaksi offline :( , mam ted pred sebou novej PC a rad bych to na to nahodil , thx
Martin Špánek :: Rajhradice.net ::
raven-il
Příspěvekod raven-il » 18 years ago
Bacha na to lidi v 133c mi po nahrati sla totalne dolu bandwidth na ethernetu, RX to jede tak 6 kB
