What's new in 6.43.7 (2018-Nov-30 09:01):
 MAJOR CHANGES IN v6.43.7:
 !) upgrade - release channels renamed - "bugfix" to "long-term", "current" to "stable" and "release candidate" to "testing";
 !) upgrade - "testing" release channel now can contain "beta" together with "release-candidate" versions;
 Changes in this release:
 bridge - properly disable dynamic CAP interfaces;
 certificate - fixed "expires-after" parameter calculation;
 certificate - fixed time zone adjustment for SCEP requests;
 certificate - properly flush old CRLs when changing store location;
 chr - fixed possible memory allocation failure when using multiple CPUs or interfaces on Xen installations;
 crs328 - fixed SFP ports not reporting auto-negotiation status;
 crs328 - improved link status update on disabled SFP and SFP+ interfaces;
 defconf - automatically accept default configuration if reset done by holding button;
 defconf - fixed default configuration loading on RB4011iGS+5HacQ2HnD-IN;
 discovery - fixed malformed neighbor information for routers that has incomplete IPv6 configuration;
 discovery - fixed neighbor discovery for PPP interfaces;
 discovery - properly use System ID for "software-id" value on CHR;
 export - fixed "silent-boot" compact export;
 health - fixed bad voltage readings on RB493G;
 interface - improved system stability when including/excluding a list to itself;
 ipsec - fixed hw-aead (H) flag presence under Installed SAs on startup;
 ipsec - improved stability when uninstalling multiple SAs at once;
 ipsec - properly handle peer profiles on downgrade;
 ipsec - properly update warnings under peer menu;
 kidcontrol - do not allow users with "read" policy to pause and resume kids;
 log - properly handle long echo messages;
 lte - added support for more ZTE MF90 modems;
 ospf - improved stability while handling type-5 LSAs;
 routerboard - renamed SIM slots to "a" and "b" on SXT LTE kit;
 routerboard - show "boot-os" and "force-backup-booter" options only on devices that have such feature;
 snmp - do not initialise interface traps on bootup if they are not enabled;
 timezone - updated timezone information from tzdata2018g release;
 traffic-flow - fixed post NAT port reporting;
 traffic-flow - fixed "src-mac-address" and added "post-src-mac-address" fields;
 tunnel - made "ipsec-secret" parameter sensitive;
 usb - fixed power-reset for hAP ac^2 devices;
 user - speed up first time login process after upgrade from version older than v6.43;
 winbox - allow to specify SIM slot on LtAP mini;
 winbox - enabled "fast-forward" by default when adding new bridge;
 winbox - fixed neighbor discovery for IPv6 neighbors;
 winbox - show "System/Health" only on boards that have health monitoring;
