Verze 6.42.7
goblajz
Verze 6.42.7
Příspěvekod goblajz » 8 years ago
*) bridge - improved bridge port state changing process;
*) crs326/crs328 - fixed untagged packet forwarding through tagged ports when pvid=1;
*) crs3xx - added command that forces fan detection on fan-equipped devices;
*) crs3xx - fixed port disable on CRS326 and CRS328 devices;
*) crs3xx - fixed tagged packet forwarding without VLAN filtering (introduced in 6.42.6);
*) crs3xx - fixed VLAN filtering when there is no tagged interface specified;
*) dhcpv4-relay - fixed false invalid flag presence;
*) dhcpv6-client - allow to set "default-route-distance";
*) dhcpv6 - improved reliability on IPv6 DHCP services;
*) dhcpv6-server - properly update interface for dynamic DHCPv6 servers;
*) ethernet - improved large packet handling on ARM devices with wireless;
*) ethernet - removed obsolete slave flag from "/interface vlan" menu;
*) ipsec - fixed "sa-src-address" deduction from "src-address" in tunnel mode;
*) ipsec - improved invalid policy handling when a valid policy is uninstalled;
*) ldp - properly load LDP configuration;
*) led - fixed default LED configuration for RBLHGG-5acD-XL devices;
*) lte - added signal readings under "/interface lte scan" for 3G and GSM modes;
*) lte - fixed memory leak on USB disconnect;
*) lte - fixed SMS send feature when not in LTE network;
*) package - do not allow to install out of bundle package if it already exists within bundle;
*) ppp - fixed interface enabling after a while if none of them where active;
*) sfp - hide "sfp-wavelength" parameter for RJ45 transceivers;
*) upgrade - fixed RouterOS upgrade process from RouterOS v5;
*) userman - fixed compatibility with PayPal TLS 1.2;
*) vrrp - fixed VRRP packet processing on VirtualBox and VMWare hypervisors;
*) w60g - added distance measurement feature;
*) w60g - fixed random disconnects;
*) w60g - general stability and performance improvements;
*) w60g - improved MCS rate detection process;
*) w60g - improved MTU change handling;
*) w60g - properly close connection with station on disconnect;
*) w60g - stop doing distance measurements after first successful measurement;
*) winbox - added "secondary-channel" setting to wireless interface if 80 MHz mode is selected;
*) winbox - fixed "sfp-connector-type" value presence under "Interface/Ethernet";
*) winbox - fixed warning presence for "IP/IPsec/Peers" menu;
*) winbox - properly display all flags for bridge host entries;
*) winbox - show "System/RouterBOARD/Mode Button" on devices that has such feature;
*) wireless - added option to disable PMKID for WPA2;
*) wireless - fixed memory leak when performing wireless scan on ARM;
*) wireless - fixed packet processing after removing wireless interface from CAP settings;
*) wireless - updated "united-states" regulatory domain information;
hol
Příspěvekod hol » 8 years ago
upgrade AP, RB912 (912UAG-5HPnD), asi je už dost starý. Upgrade z verze 6.32.3 proběhl ok a vše fungovalo. Během cca hodiny spadly signály klientům cca o 20 dolů a zůstali tam viset jen ti, co mají verzi 6.41 a víc. Ostatní se odpojili. Log se bohužel nedochoval, blbě nastavenej. Nic na bezdrátu jsem neměnil, je tam NV2.
Udělalo to 2x, pak návrat na verzi 6.36.3 - downgrade bez problémů, klienty čas ukáže.
Co je ještě divné, že RB fw je verze 3.33 a vyšší verzi to nenabízí. Tak nevím, zda to nemá nějakou souvislost.
pepulis
Příspěvekod pepulis » 8 years ago
Poslední verzi používám jak na RB 912, tak 922 a vse probehlo v poradku, i update fw. Signal klientum drzi.
Také mám na 922 (resp. netmetalech) fw 6.42.7. Ale je fakt, že jsem nikdy neměl tak velkou 'mezeru' v aktualizacích.
oliver.es
Příspěvekod oliver.es » 8 years ago
Ahoj všem,
po upgrade CCR1072 z předchozí "zabezpečené" verze (bylo to něco kolem 6.4X.X) na verzi 6.42.7 pozorujeme zvýšený jitter, který se projevuje i na smokepingu a zákazníci hlásí přerušování RTSP streamů. Nevím zda tyto dvě věco spolu mohou souviset nebo ne. Nemáte někdo obdobné zkušenosti?
Děkuji
Na screenu je moment upgrade označen červenou šipkou.
hapi3
Příspěvekod hapi3 » 8 years ago
ty střílíš 100 icmp za 1 minutu? podíval si se do mísy jestli máš zdravý hovno? a co ta všudepřítomná modrá čára? ta nevadí?
