RB962 a PoE out
BOBIK
RB962 a PoE out
Příspěvekod BOBIK » 8 years ago
Ahoj mate zkusenosti kolik se muze pres RB962 cpat pres PoE out? Nikde v datasheetu jsme to nenasel?
Jde mi o to ze kdyz pripojim 48V zdroj a 2A a chtel bych neco takoveho dostat ven z miklrotiku pres PoE out zda v nem neco neodpalim.
Dik
Co by si stym chcel napajat konkretne ? Pocital by som s vystupom tak 0,5A max. Takze pri 48V to mas okolo 24W.
https://i.mt.lv/routerboard/files/15301 ... -ac-qg.pdf
The Ether 5 port supports PoE output for powering other RouterBOARD devices. It has an auto detection feature,so you can connect Laptops and other non-PoE devices without damaging them. The PoE on Ether5 outputsapproximately 2 V below input voltage, and supports up to 0.7 A (So provided 24 V PSU will provide 22 V 0.7 Aoutput to the Ether 5 PoE port).
