6.1.7
svestka
Příspěvekod svestka » 8 years ago
6.1.7 (XM/XW/TI) Changelog / May 25, 2018
New:
- New: Support for the new TDD Framing Flexible (NEW) mode (airMAX AC AP on v8.5.4 required)
- New: TDD Framing/GPS Sync support for 10MHz in AP PtMP airMAX Mixed mode (airMAX AC AP on v8.5.4 required)
- New: IPV6 addresses support in the Ping tool
- New: Daylight Saving Time support
- New: ULink, UNMS, UCRM icons on Login page
- New: UNMS agent upgrade to v0.3.12
- New: Updated EULA and Privacy Policy agreements
Regulatory updates:
- Updated New Zealand allowed frequencies for 5GHz
Improvements:
- airOS stability improvements
Fixes:
- Fix: Allow configuring local or static IPv6 address on LAN even IPv6 is not set on WAN
- Fix: Need restart dnsmasq service after IPV6 gets DNS from DHCP
- Fix: Make DHCPv6 Unique Identifier (DUID-UUID) permanent
- Fix: DNS configuration when DHCP on WAN is selected
- Fix: No internet access for LAN clients with specific DHCP server and DNS proxy configurations (router mode)
- Fix: Wrong airMAX Quality reporting of 1x1 chain devices
- Fix: Station cannot connect to 40MHz AP for New Zealand country
- Fix: Reduce IPv6 server and client syslog messages
WEB UI:
- WEB UI: Remote stats are missing in case "Extra reporting" is enabled but related cfg key is missing
- WEB UI: airMAX Capacity reporting issue in VHT10 mode
- WEB UI: Various small UI improvements
miko
Příspěvekod miko » 8 years ago
Jeden Rocket s XW chipsetom sa mi s tymto firmware vkuse preladuje na frekvencie ake sa mu zachce.
Frequency List mam prazdny, pouzival len 1 freq, a aj tak sa preladi.
Tak nech zije 6.1.6
lyra
Příspěvekod lyra » 8 years ago
No tohle ale u některeho HW dělá již od odhadem od verze 5,62. Zamknout frekvenční list na 1 frekvenci , jinak to je to v haji.
Nahral jsem to asi na cca 200 zařízení už, zatim žadné porovnání nevidím rozdíl.
miko
na 6.1.6 mi to nerobilo. Vcera som spravil downgrade a mam pokoj. Takze zavisle to je aj od fw, nie len od hw.
Inak, tiez vyse 200 zariadeni upgradnutych a ziadny problem, rocket s XW mam v sieti len jediny.
gavanet
Příspěvekod gavanet » 8 years ago
UNMS mi nabízí upgrade na verzi 6.1.7 nebo na 6.1.7-cs. Víte někdo v čem je rozdíl?
EDIT: https://community.ubnt.com/t5/airOS-Sof ... -p/1624488
Naposledy upravil(a) gavanet dne 13 Jun 2018 11:30, celkem upraveno 1 x.
"cs" - custom scripts. Normální firm je totiž zakazuje.
