What's new in 6.41.4 (2018-Apr-05 12:23):
!) tile - improved overall system performance and stability ("/system routerboard upgrade" required);
*) led - fixed unused "link-act-led" LED trigger on RBLHG 2nD, RBLHG 2nD-XL and RBSXTsq 2nD;
*) led - removed unused "link-act-led" trigger for devices which does not use it;
*) netinstall - sign Netinstall executable with an Extended Validation Code Signing Certificate;
*) poe - do not show "poe-out-current" on devices which can not determine it;
*) poe - hide PoE related properties on interfaces which does not provide power output;
*) winbox - made UDP local and remote TX size parameters optional in Bandwidth Test tool;
*) winbox - show dual SIM options only for RouterBOARDs which does have two SIM slots;
*) winbox - use proper graph name for HDD graphs;
*) wireless - enable all chains by default on devices without external antennas after configuration reset;
Verze 6.41.4
disk
