What's new in 6.40.5 (2017-Oct-31 13:05):
*) certificate - fixed import of certificates with empty SKID;
*) crs3xx - fixed 100% CPU usage after interface related changes;
*) firewall - do not NAT address to 0.0.0.0 after reboot if to-address is used but not specified;
*) ike1 - fixed crash after downgrade if DH groups 19,20,21 were used for phase1;
*) ike1 - fixed RSA authentication for Windows clients behind NAT;
*) ipsec - fixed lost value for "remote-certificate" parameter after disable/enable;
*) ipv6 - fixed IPv6 addresses constructed from prefix and static address entry;
*) log - properly recognize MikroTik specific RADIUS attributes;
*) lte - do not reset modem when it is not possible to access SMS storage;
*) lte - fixed modem initialization after reboot;
*) lte - fixed PIN option after setting up the band;
*) sms - include time stamps in SMS delivery reports;
*) sms - properly initialize SMS storage;
*) snmp - fixed "/system license" parameters for CHR;
*) winbox - allow shorten bytes to k,M,G in Hotspot user limits;
*) wireless - fixed rate selection process when "rate-set=configured" and NV2 protocol is used;
Verze 6.40.5
Jen taková blbost - dnes jsem instalovat nový router RB3011 a když to leželo na stole tak si kolega "hrál" s tím jeho LCD a tak vím, že to fungovalo... Na konec konfigurace jsem tam dal tento FW a když jsem to nacpal do racku a jen ze zvědavosti jsem tam chtěl dát graf - dotyk nefunguje - máte někdo 3011 s touto verzí? Nevím jestli je to tím upgradem a nebo to prostě na novém kusu umřelo... Děkuji předem!
Dotyk se dá zapnout/vypnout v menu.
