L2TP problem - alternativa ? SSTP ?
sestnastka
Příspěvekod sestnastka » 9 years ago
Ahojte, dlhsiu dobu sa mi nedari rozchodit L2TP/IPSEC /ROS je najnovsi/
Zvlastne je, ze na Android 5.0 funguje...
Dokonca som v registroch Windows povoloval NAT-T aby som sa dostal na moje NAS QNAP...
Najviac ma na tom stve, ze ono mi to raz po prvom nastaveni islo - dokonca aj SMB sharing... po par tyzdnich ked to chce clovek na nieco, nefunguje to. Zaroven, mae skusenosti so SSTP ? Vytvorim certifikaty na MiktroTiku /self-signed) podla mnohych navodov na NETe no Win mi ich nezozerie... SSTP bezi na 443 cize sa nikdy nestane, ze mi bude blokovat porty nejaky ISP... premyslam dobre ?
Budem rad za vase cenne skusenosti...
Moje nastavenia:
SERVER
[admin@Sestnastka_ROUTER] /interface l2tp-server server> print
            enabled: yes
            max-mtu: 1450
            max-mru: 1450
               mrru: disabled
     authentication: mschap1,mschap2
  keepalive-timeout: disabled
       max-sessions: unlimited
    default-profile: L2TP
          use-ipsec: no
       ipsec-secret: heslo
     caller-id-type: ip-address
    allow-fast-path: no
admin@Sestnastka_ROUTER] /ppp profile> print
Flags: * - default
 0 * name="default" use-mpls=default use-compression=default use-encryption=default
     only-one=default change-tcp-mss=yes use-upnp=default address-list="" on-up=""
     on-down=""
 1   name="L2TP" local-address=ether2 remote-address=L2TP/IPsec use-mpls=default
     use-compression=default use-encryption=required only-one=default
     change-tcp-mss=default use-upnp=default address-list="" dns-server=8.8.8.8,8.8.4.4
     on-up="" on-down=""
 2 * name="default-encryption" use-mpls=default use-compression=default use-encryption=yes
     on-down=""
Poznamka: local address z rozsahu 192.168.2.0/24, remote - jedina addresa vytvorena cez POOL: 192.168.6.10
admin@Sestnastka_ROUTER] /ppp secret> print
Flags: X - disabled
 #   NAME          SERVICE CALLER-ID         PASSWORD         PROFILE         REMOTE-ADDRESS
 0   sestnastka    l2tp                                    heslo           L2TP
admin@Sestnastka_ROUTER] /ip pool> print
 # NAME                                                       RANGES
 0 ether2                                                     192.168.2.10-192.168.2.100
 1 ether3                                                     192.168.3.10-192.168.3.100
 2 ether4                                                     192.168.4.10-192.168.4.100
 3 ether5                                                     192.168.5.10-192.168.5.100
 4 WIFI2.4                                                    192.168.24.10-192.168.24.100
 5 WIFI5                                                      192.168.50.10-192.168.50.100
 6 L2TP/IPsec                                                 192.168.6.10
 7 NAVSTEVA                                                   192.168.60.10-192.168.60.20
0   R address=0.0.0.0/0 auth-method=pre-shared-key secret="heslo"
       generate-policy=port-override policy-template-group=default exchange-mode=main-l2tp
       send-initial-contact=yes nat-traversal=yes proposal-check=obey hash-algorithm=sha1
       enc-algorithm=aes-256,aes-128,3des dh-group=modp2048,modp1024 lifetime=1d
       dpd-interval=2m dpd-maximum-failures=5
[admin@Sestnastka_ROUTER] /ip ipsec proposal> print
Flags: X - disabled, * - default
 0  * name="default" auth-algorithms=sha1 enc-algorithms=aes-256-ctr,3des lifetime=30m
      pfs-group=none
 0    ;;; VZDIALENY PRISTUP Z WINBOXu
      chain=input action=accept protocol=tcp dst-port=8291 log=no log-prefix=""
 1    chain=forward action=accept connection-state=established,related
      connection-nat-state="" in-interface=ether1 log=no log-prefix=""
 2    chain=forward action=accept connection-state=established,related log=no log-prefix=""
 3    ;;; Povol L2TP VPN protokol 50
      chain=input action=accept protocol=ipsec-esp log=no log-prefix=""
 4    ;;; Povol L2TP VPN protokol 51
      chain=input action=accept protocol=ipsec-ah log=no log-prefix=""
 5    ;;; Povol L2TP VPN port 1701
      chain=input action=accept protocol=udp dst-port=1701 log=no log-prefix=""
 6    ;;; Povol L2TP VPN port 500
      chain=input action=accept protocol=udp dst-port=500 log=no log-prefix=""
 7    ;;; Povol L2TP VPN port 4500
      chain=input action=accept protocol=udp dst-port=4500 log=no log-prefix=""
CLIENT
Windows 7 Home - viz priloha. Este podotknem, ze z MikroTik pingnem aktuane pridelenu addressu napr. 192.168.2.98 ale z NB nepingnem nic (akoby som vobec nebol pripojeny) ale v MT vidim, ze som tam..
Ak bude potreba este nieco sem hodit, daj vediet.
maartinek
Příspěvekod maartinek » 9 years ago
Ahoj.
Zkus nastavení podle obrázku. To je moje a funkční. Hlavně nezapomeň na PreShared Key.
sestnastka
Aj toto som uz skusal, preshared key mam vyplneny... nechapem, akoto ze na Android telefone mi to ide, vcera cez mobilny netO2 som sa cez apku ES-File explorer dostal na domace ulozisko cez SMB aj SFTP...
