Verze 6.33.6
goblajz
Verze 6.33.6
Příspěvekod goblajz » 10 years ago
What's new in 6.33.6 (2016-Jan-28 12:06):
*) winbox - show properly route-distinguisher for bgp vpn4;
*) winbox - show dhcp server name in dhcp leases;
*) ppp - make CoA work correctly with address-lists;
*) winbox - fixed tab names to correspond to console;
*) winbox - show only actual switch-cpu ports in switch setting combobox;
*) winbox/webfig - fixed version column ordering in ip neighbors list;
*) webfig - fixed switch port "default vlan id" has missing "auto" value;
*) webfig - fixed firewall connection-bytes option;
*) ipsec - fixed kernel failure after underlying tunnel has been disabled/enabled;
*) romon - allow to see device identity if it is longer than 31 character;
*) fastpath - show fp counters in /interface monitor aggregate;
*) bridge firewall - fix chain check (broken since 6.33.2);
*) bridge firewall - fixed crash when jump rule points to disabled custom chain;
*) smb - fix crash when changing user which has open session;
*) address-list - properly remove unused address-lists from drop-downs;
*) fetch - fixed closure after 30 seconds;
*) capsman - fix radius accounting stop message;
*) log - reopen log file if deleted;
*) packing - fix tcp/udp checksums when simple packing is used;
*) tile - fix ipsec freeze after SA updates;
*) upnp - fixed missing in-interface option for dynamic dst-nat rules;
*) tunnel - fix complaining about loop after ~248 days;
*) vrrp - make sure that VRRP gets state on bootup;
*) ppp - fixed rare kernel crash (introduced in v6.33);
*) ppp - do not allow empty name ppp secrets;
*) ssh - fix active user accounting.
petr
Příspěvekod petr » 10 years ago
Chyba s balíčkem wireless.npk v aktualizaci přes System-Packages-Check For Updates-Downlload&Install nejen zůstala, ale je to ještě mnohem horší: Po spuštění aktualizace zmíněným způsobem a máte-li ve starší verzi nainstalován balíček wireless (byť vypnutý), nelze přes winbox už akualizovat vůbec.
Teď nemám čas se o to znovu pokoušet, vrátím se k tomu později. Vypadá to ale, že jinak než přes Netinstall už asi to nepůjde. Ověřeno zatím jen na mipsbe. Doufám, že pomůže vypnout/zapnout.
goblajz
Verzi nahradila záhy verze 6.34
petr píše:Chyba s balíčkem wireless.npk v aktualizaci přes System-Packages-Check For Updates-Downlload&Install nejen zůstala, ale je to ještě mnohem horší: Po spuštění aktualizace zmíněným způsobem a máte-li ve starší verzi nainstalován balíček wireless (byť vypnutý), nelze přes winbox už akualizovat vůbec.
chyba? myslíš to, že wireless balíček už neexistuje? Proto to nefunguje.
Na druhou stranu to mají mít ošetřené. Buď nepovolit upgrade, nebo ho nahradit tím -fp, což by problém způsobit nemuselo. Takto se člověk většinou projede ...
petr
hapi píše:
Přesně tak:
Systém po pokusu o upgrade sice funguje, ale zatížení CPU je na 100%. Nelze se toho zbavit restartem ani cestou vypnout/zapnout.
Lze to ale snadno napravit odinstalováním balíku wireless. RB ale reaguje s obrovskou prodlevou, vyplatí se počkat.
Vyzkoušel jsem na RB411A (na půdě) a pro ověření následně na RB433AH (na stole). Jak to bude u v.6.34 netuším. Na vzdálených RB raději nebudu upgrade, bez předchozího smazání balíku wireelss, vůbec zkoušet. Je ovšem také moje chyba, že jsem balík už dávno nesmazal.
Na rozdíl od katastrofického chování DFS na UBNT v novějších verzích FW :shock: je taková chyba ovšem brnakčka.
