Nová 5.6.3
Striker
Nová 5.6.3
Příspěvekod Striker » 11 years ago
AirOS V Firmware Revision History
Supported products
* Bullet M2/M5/Titanium
* Rocket M2/M2 Titanium/M3/M365/M900/M5/M5 GPS/M5 Titanium/M6
* NanoStation M2/M3/M365/M5/M6
* NanoStation Loco M2/M900/M5
* NanoBridge M2/M3/M365/M900/M5
* AirGrid M2/M5/HP/HP New
* PowerBridge M3/M365/M5/M10
* LiteBeam M5
* PicoStation M2
* AirRouter/HP
* PowerAP N
Version 5.6.3-Service release (November 30, 2015)
Regulatory updates:
- New: Enable UNII2 band after Revised UNII Rules activation for certified models (United States/Puerto Rico)
- New: Revised UNII Rules activation for certified models:
Rocket M5
NanoBridge M5
PowerBeamM5 300/400/620
NanoBeam M5 16/19
- Fix: Revised UK/DFS rules
- Fix: Disabled UNII2 frequencies for AP-Repeater after Revised UNII Rules gets activated (FCC regulatory restrictions)
- Fix: Limit channel width to 20MHz for Indonesia
- Fix: Reduce EIRP for Pakistant to 20dBm/100mW (5GHz)
Improvements:
- New: Linux kernel upgrade to 2.6.32.68 (possible fix for random AP reboots)
- New: DHCP server IP range is suggested according LAN IP address/netmask values
- New: Antenna model selection in Wireless page
- New: Allow to disable remote statistics reporting via Extra Reporting option in Advanced configuration page
- New: Default password change request before applying configuration changes
Fixes:
- airMAX: Security improvements
- Fix: Generate SSL certificate start date from firmware build timestamp
- Fix: Network settings are not fully loaded in case if bridge section is missing in configuration file
- Fix: AP crash prevention in power save mode
- Fix: Incorrect antenna selection for Rocket M900
- Fix: DFS AP doesn't change channel after NOL timeout
- Fix: Don't require to change default password if configuration backup was uploaded with updated credentials
- Fix: Egress traffic is limited on VLAN interfaces when rules are set on parent
- Fix: Simplified airView tool launch
- Fix: Enable airView for LiteBeam M5 23
- Fix: Optimise remote statistics collection to reduce infctld CPU usage
- Fix: Improve frequency scan for XW series radios
- Fix: PHP2 buffer overflow
- Fix: Station doesn't connect back to AP after it was kicked or AP was rebooted
- Fix: Reduce remote statistics bursts from AP and randomise transmit interval
- Fix: Remove Station only and airMAX only restriction for LiteBeam M5 23 product
- Fix: Improve AC2 agent response to server after device reboot
- Fix: Wrong frequency list after session timeout
- Fix: Respond on wireless interface for discovery requests when PPPoE client is configured
- Fix: Validate overlapping 30MHz width channels
- Fix: Enabling "Hide Indoor Channels" cause station to lockup
- Fix: wpa_supplicant no timestamp check
- WEB UI: Translations update
- WEB UI: Device Name displaying incorrectly when using symbol &
- WEB UI: Show possible LAN negotiation speed for gigabit capable devices
- WEB UI: TX Power reporting in MAIN page when set 0dBm
- WEB UI: Show antenna gain input field for devices which have single antenna option and no built-in antenna
- WEB UI: Show correct antenna in main tab if there are two antennas with same gain value
- WEB UI: Move Refresh button to top of the Stations list
- WEB UI: Hide TX signal in Station list if remote statistics are disabled
- WEB UI: TX power slide doesn't allow dragging
No nepříjde mi tam nic moc užitečného :)
bezdratsmrdi
Příspěvekod bezdratsmrdi » 11 years ago
Ne? a co třeba tohle?
že by to konečně začlo i skenovat jinak než že to naskenovalo sítě na jednom dvou kanálech a pak to zdechlo a na další sken se to vyprdlo? Hlavně vzdálený sken v 99 procentech případů chcípnul po pár nalezených SSID
taky podstatnej bug, sice už se tolik neprojevoval, ale občas nepotěšil
svestka
Příspěvekod svestka » 11 years ago
zatím se to tváří OK, AP i CLI, router i bridge módy, PtP i PtMP
jen ten překlad WEBUI do češtiny někdo trochu přepískl :D
Jarin
Příspěvekod Jarin » 11 years ago
Já jsem to dal na ve čtvrtek na nově instalované Rockety M5 a během 24 hodin, několik rebootů. Tak jsem je včera vrátil na 5.5.10 a právě nyní je to 24 hodin bez rebootu. Nějak se to nesneslo.
gsmsoft
Příspěvekod gsmsoft » 11 years ago
To iste mam na trase NanoBeam M5 reboot naspet som dal 5.5.10 a vsetko ok
Striker
Jo to WEBUI v CZ je katastrofa :D
Je fakt, že to s tím scanem se mi teď stalo na 5.6.2- že to naskenovalo tak 10 sítí jiank nic a asi 5x po sobě. Ale předtím se mi to ještě nestalo. Na 5.6.3 jsem to ještě nezkoušel.
susta
Příspěvekod susta » 11 years ago
Čeština je v té verzi tragická a scan opraven není!!!! Jednou to skenuje dobře jednou tam kanály chybí.
wifi-pc
Příspěvekod wifi-pc » 11 years ago
sken je stále stejne na h.....
svestka
susta píše:Čeština je v té verzi tragická a scan opraven není!!!! Jednou to skenuje dobře jednou tam kanály chybí.
Traffic shaping přeložený jako Formování provozu :-D jsem chvíli slzel :)
scan jede dobře po restartu zařízka, po pár dnech provozu začíná blbnout - skenuje jen aktuální kanál co má naladěný apod. :(
petr
Příspěvekod petr » 10 years ago
Tato verze je v některých lokalitách kvůli nemožnosti vypnout DFS naproto nepoužitelná. Tam kde funguje v.5.6.2, se NB s v.5.6.3 vůbec nespojí. Už skoro měsíc komunikuji se supportem, ale k ničemu to zatím nevede. Snad se to podaří vyřešit.
Navíc jsem přišel na to, že nemohu vůbec nahrát konfiguraci, ani tu, kterou jsem z ní právě uložil.
Zatím asi nejlepší verzí je v.5.5.4, kterou ovšem nelze dostat do NanoBeamu.
petr píše:Tato verze je v některých lokalitách kvůli nemožnosti vypnout DFS naproto nepoužitelná. Tam kde funguje v.5.6.2, se NB s v.5.6.3 vůbec nespojí. Už skoro měsíc komunikuji se supportem, ale k ničemu to zatím nevede. Snad se to podaří vyřešit.
5.5.6 tam dostanes.
Striker
Příspěvekod Striker » 10 years ago
Ano 5.5.6 se tam dá dostat ale už se mi hodněkrát stalo, že po nahrání 5.5.6 se mi NanoBeam seknul, nic nenaskenoval a po jakékoliv změně nastavení se sám vyresetoval. Od té doby nepoužívám radši vůbec.
Popřípadě pokud někdo máte fukční FW na 5.5.6 na PowerBeam M5 budu rád, za SZ a jeho zaslání! Ten co jsem našel já dělá to co popisuji, tak nevím jestli to je FW.
lyra
Příspěvekod lyra » 10 years ago
Ja to doma testnul na Lite Beam .. puvodni firmware 5,62 mi nedovolilo pripojit skoro nikam a ta verze 5,63 už připojuje be problemu. Mam to v provozu od soboty a zatim bez chyby . Čeština je zvláštní jistě
Nenašel jsem problem ve scenu , možna je to chyba i určiteho typu.
www.wiracom.cz -
petr
KoZLiCeK píše:
5.5.6 tam dostanes.
U verze 5.5.6 také nejde vypnout DFS. V textové konfiguraci lze sice nastavit DFS disabled, ale stejně se detekce radaru nevypne.
S v.5.6.3 se mi v poměrně zarušeném prostředí dokonce stalo to, že ačkoli byl nastaven kmitočet nastaven napevno, Rocket M5 se samovolně přeladil na indoor frekvenci. Příklad z praxe: v záložce Wireless byla nastavena frekvence 5620MHz (a zůstala tam i po samovolném přeladění), ale v záložce Main se objevila frekevnce 5180MHz. To je na pokutu od ČTÚ!!! Ještě, že jsem si toho včas všiml. Na kom bych asi mohl proplacení pokuty vymáhat :shock:
Poprvé jsem chybu hledal u sebe a znovu vše nastavil. Když se to ale stalo podruhé, honem jsem se vrátil k v.5.5.4. Takové situaci lze sice předejít vhodným nastavením s vyloučením indoor frekvencí, ale ani ve snu mě nenapadlo, že se něco takového vůbec může stát.
Maník ze supportu se sice snaží, navrhuje, jak to řešit a pořád mě vyzývá k odpovědi. Vyzkoušel jsem jeden nápad i druhý, další už ne. Nemám na to čas, UBNT mám v síti několik set, jen na páteřních spojích kolem 30. Naštěstí však mám na většině páteří Mikrotiky. UBNT s firmware XW (pro které neexistuje legální verze 5.5.4) mám díky Bohu jen několik.
lyra
Ano toto jsem také zjistil u vysílaní opravdu to je hooodně velky bug :
Skutečne v režimu AP to skutečně vybírá náhodně jakékoliv kanaly včetně indor i když byly zatržitkem zakázané.
Ja to nepotřeboval na AP jen jsem to testnul a myslel jsem si že špatně vidím. Ale jako klient se to tvaři bez problemu - jedu ted přes něj.
www.wiracom.cz
