Verze 6.31
goblajz
Verze 6.31
Příspěvekod goblajz » 10 years ago
What's new in 6.31 (2015-Aug-14 15:42):
*) check-for-update - added ability to select versions channel to check
(bugfix, current, RC or development)
*) demo mode of Cloud Hosted Router (CHR) added
*) chr - added x86_64 image for use in virtual environments
*) chr - added support for VMware SCSI virtual disks
*) chr - added support for VMware vmxnet3 network card
*) chr - added support for HyperV SCSI disks
*) chr - added support for HyperV Ethernet interfaces
*) chr - added support for virtio disks
*) fixed occasional interface resetting on CRS switches
*) fixed ethernet stopping on RB NetMetal / SXTG-5HPacD 10Mbit and 100Mbit links
*) ipsec - fixed crash in when gcm encryption was used
*) ipsec - allow to set peer address as "::/0"
*) ipsec - fixed empty sa-src address on acquire in tun mode
*) ipsec - show proposal info in export ipsec section
*) ipsec - preserve port wildcard when generating policy without port override
*) ipsec - fixed replay window, was accidentally disabled since version 6.30;
*) certificate manager - fixed memory leak
*) ssh - allow host key import/export
*) ssh - use 2048bit RSA host key when strong-crypto enabled
*) ssh - support RSA keys for user authentication
*) conntrack - fixed problem with manual connection removal
*) conntrack - added tcp-max-retrans-timeout and tcp-unacked-timeout
*) wireless - implemented l2mtu update if wireless-cm2 is enabled
*) wireless - improved WMM-PowerSave support in wireless-cm2 package
*) mpls - better multicore support for VPLS ingress/egress
*) ovpn - better multicore support for interface initialization/authentication/creation.
*) mesh - performance improvement
*) pptp & l2tp - fixed problem where android client could not connect if both dns names were not provided (was broken since v6.30)
*) user-manager - fixed username was not shown in /tool user-manager user
*) user-manager - fixed zoom for user-manager homepage when mobile devices used
*) winbox - restrict change dynamic interface fields
*) winbox - also hide passphrase in CAPsMAN with "Hide Password"
*) winbox - restrict reversed ranges in dst-port under firewall
*) quickset - fixed HomeAP mode
*) lcd - added LCD package for all architectures (for serial port LCD modules)
*) lcd - fixed crash (and 100% cpu usage) when interface gets removed from "stats-all" screen
*) tool fetch - fixed incomplete ftp download
*) tool fetch - don't trim [t]ftp leading slashes
*) proxy - adjust time according to time-zone settings in proxy cache contents.
*) bridge fastpath - fixed updating bridge FDB on receive (could cause TX traffic flooding on all bridge ports)
*) bonding fastpath - fixed possible crash when bonding master was also a bridge port
*) route - fixed crash on removing route that was aggregated
*) romon - fixed crash on SACKed tx segments
*) lte - improved modem identification to better support multiple identical modems
*) snmp - fixed system scripts table
*) traffic flow - fixed dynamic input/output interface reporting
*) ipv6 dhcp-relay - fixed problem loading configuration
known issue:
*) Dynamic DNS servers can disappear when "allow-remote-requests" are not enabled
ikk
Příspěvekod ikk » 10 years ago
Peklo zamrzlo??? :evil: :D
Síť není jen internet ...
pasl
Příspěvekod pasl » 10 years ago
pozor RB600
záložka wi-fi karty bez manipulace s heslem NV2 tak při potvrzení vloží **************
jestli i jiné rbčka nevím, protože beňo je drahá sranda.
Dalibor Toman
Changelog zrejme zase neni uplny. Problemy s ethernetem zminuje jen u RB NetMetal / SXTG-5HPacD ale presto mi prislo od supportu:
Hello,
I would like to inform you that the ethernet stopping problem you had experienced
with RB922UAGS is fixed RouterOS v6.31. I recommend to upgrade RB922UAGS to this
version.
Regards,
Janis B.
ikk
Zdravím všechny.
Už jsem dostal radost, že RouterOS podporuje VMware vmxnet3. Ale asi někde dělám chybu. Nahrál jsem potřebné balíčky (neinstaluji vše, jen to co potřebuji), nastavil ESXi a nic. Prostě ji nevidí :(
Můžete prosím někdo poradit jak správně postupovat?
PS: Instaloval jsem 6.31 z 14.8.2015, podpora by měla být zahrnuta od verze 6.31rc14 a výše.
tak verze 6.31 stále neřeší problém samovolných watchdog resetů u UP RB zařízení, ale snad by to mohlo být opraveno v bugfix veri, jelikož se o tom začal zajímat i normis...
ikk píše:Zdravím všechny.
Myslím že se to týkán jen virtuálu CHR - Cloud Hosted Router
ikk
honzam píše:Myslím že se to týkán jen virtuálu CHR - Cloud Hosted Router
I tak super zpráva. Akorát se trochu bojím jejich cenové politiky. Hlavně mám strach z toho předplatného. Radši zaplatím jednorázovou cenu. V každém případě posun správným směrem, tak uvidíme jak to ještě dopadne :)
Tomáš Nesrsta
Příspěvekod Tomáš Nesrsta » 10 years ago
RB411, RB711UA - u obou se mi projevil stejný problém. RB se cca do 4 hodin zasekne. Po odpojení napájení zase nejakou dobu jede...
Bývalý ISP...
michnzee
Příspěvekod michnzee » 10 years ago
U této verze je také problém s HIDE & SHOW password :) když si rozkliknete nějaký seznam s hesly, show / hide password funguje. Když si ale rozkliknete nějakou konkrétní položku, tam už show / hide nefunguje a zůstávají tam stále hvězdičky. Dokonce se mi nahodile zdá, že když takové okno otevřu, vyzkusím show / hide a potvrdím, uložené heslo (které tam doposud bylo) záhadně neplatí a musím ho manuálně přepsat. Alespoň u tunelů mi to takto zlobilo...
::RouterLEGOboard::
pedro4444
Příspěvekod pedro4444 » 10 years ago
bacha upgrade 750up z 6,30 na 6,31 a uz sa nenahodila musel som zo zasuvky vytiahnut dal som spat 6,28 a vsetko ide ako ma...
RB450G - trvá to trochu déle (pět dnů) a rozeběhne se to nakonec samo (watchdogem) po šesti hodinách ...
Tomáš Nesrsta píše:RB411, RB711UA - u obou se mi projevil stejný problém. RB se cca do 4 hodin zasekne. Po odpojení napájení zase nejakou dobu jede...
ferrys
Příspěvekod ferrys » 10 years ago
Pozor na tento FW najednou nam slo do kytek 20 bouardu - jen ping jinak death :) asi po tejdnu ... nevim cim to :)
jame.el
Příspěvekod jame.el » 10 years ago
Musím říci že na RB951 a hAP v režimu CapsMan mám lepší výsledky propusnoti a 6.31 je na nich stabilní, totálně však vyhořel na omnitikách, ty se neustále zasekávají a přihlášení do nich je možné až po restartu napájení.
