Netinstall nejede...
aj_rade
Příspěvekod aj_rade » 18 years ago
Zdravim,
mam takovyto problem: Po upgradu rb112 pres lan doslo k vypadku elektriny a tak se neoprovedl dany upgrade a rb112 nyni nenabootuje.
Hodil sem si pres seriak vystup na konzoli a vidim, ze boot loader je ok.
Tak se mstahnul netinstall s 2.9.39 a zkousim marne to instalovat.
Pro nazornost posilam vypis z logu terminalu:
RouterBOOT booter 2.6
RouterBoard 112
CPU frequency: 175 MHz
Memory size: 16 MB
Press any key within 2 seconds to enter setup..
kernel not found
trying bootp protocol.... OK
Got IP address: 192.168.3.5
resolved mac address 00:08:A1:0E:38:3D
transfer started .................. transfer ok, time=2.33s
setting up elf image... OK
jumping to kernel code
[?25lWelcome to MikroTik Router Software remote installation
Press Ctrl-Alt-Delete to abort
mac-address: 00:0C:42:07:B3:58
software-id: ****-*** key:
Waiting for installation server...
....po teto hlasce se jiz nic nezobrazi a po ethernetu nic neleze.
Spojeni se mi hlasi ve windows jako 10mbit potom.... na rb112 sviti pouze jedna ledka...
Co s tim? Meli jste nekdo podobnou zkusenost?Podobnej dotaz zde zaznal, ale bez reakce, jen jeden doporucil reklamaci...
aj_rade
Tak problem jiz vyresen, netinstall dal memu rb112 IP bez masky, tj. 32 only, takze bylo nutne zadat misto /24 v netinstallu /32 a uz to slape :)
Upgrade dopadl OK
