Verze 6.30
Verze 6.30
What's new in 6.30 (2015-Jul-08 09:07):
*) wireless - added WMM power save suport for mobile devices;
*) firewall - sip helper improved, large packets no longer dropped;
*) fixed encryption 'out of order' problem on SMP systems;
*) email - fix sending multiple consecutive emails;
*) fixed router lockup on leap seconds with installed ntp package;
*) ccr - made hardware watchdog work again (was broken since v6.26);
*) console - allow users with 'policy' policy to change script owner;
*) icmp - use receive interface address when responding with icmp errors;
*) ipsec - fail ph2 negitioation when initiator proposed key length does not match proposal configuration;
*) timezone - updated timezone information to 2015e release;
*) ssh - added option '/ip ssh stong-crypto'
*) wireless - improve ac radio coexistence with other wireless clients, optimized transmit times to not interfere with other devices;
*) console - values of $".id", $".nextid" and $".dead" are avaliable for use in 'print where' expressions;
*) console - ':execute' command now accepts script source in "{}" braces, like '/system scripts add source=' does;
*) console - ':execute' command now returns internal number of running job,
that can be used to check and stop execution. For example:
:local j [:execute {/interface print follow where [:log info "$name"]}]
:delay 10s
:do { /system script job remove $j } on-error={}
*) console - firewall 'print' commands now show all entries including dynamic, 'all' argument now has no effect;
*) ipsec - increase replay window to 128;
*) fixed file transfer on devices with large RAM memory;
*) pptp - fixed "encryption got out of sync" problem;
*) ppp - disable vj tcp header compression;
*) api - reduce api tcp connection keepalive delay to 30 seconds, will timeout idle connections in about 5 minutes;
*) pptp & l2tp & sstp client: support the case were server issues its tunnel ip address the same as its public one;
*) removed wireless package from routeros bundle package, new wireless-fp is left in place and wireless-cm2 added as option;
*) pptp & l2tp client: when adding default route, add special exception route for a tunnel itself (no need to add it manually anymore);
*) improved connection list: added connection packet/byte counters,
added separate counters for fasttrack, added current rate display,
added flag wheather connection is fasttracked/srcnated/dstnated,
removed 2048 connection entry limit;
*) tunnels - eoip, eoipv6, gre,gre6, ipip, ipipv6, 6to4 tunnels have new property - ipsec-secret - for easy setup of ipsec encryption and authentication;
*) firewall - added ipsec-policy matcher to check wheather packet was/will be ipsec processed or not;
*) possibility to disable route cache - improves DDOS attack handling performance up to 2x (note that ipv4 fastpath depends on route cache);
*) fasttrack - added dummy firewall rule in filter and mangle tables to show packets/bytes that get processed in fasttrack and bypass firewall;
*) fastpath - vlan interfaces support fastpath;
*) fastpath - partial support for bonding interfaces (rx only);
*) fastpath - vrrp interfaces support fastpath;
*) fixed memory leak on CCR devices (introduced in 6.28);
*) lte - improved modem identification to better support multiple identical modems;
*) snmp - fix system scripts table;
eKrajnak
Pri toľkých zmenách ... až strach to vôbec otestovať :D
Příspěvekod Pintero » 11 years ago
Taky jsem to chtel napsat....
Zajimave je, ze porad kupuju SXT s verzi 5.26.....
k3dt
Příspěvekod k3dt » 11 years ago
RB2011 nam ukazuje 1016 Voltu :shock: kvalitka 8)
když už konečně začali psát podrobnějc changelog tak si začnete zase stěžovat na něco jinýho :-D
sxt s verzí 5.26 kupuješ proto, že tvůj dodavatel má asi velký zásoby a nebo malou prodejnost. Běžně kupujem tušim s 6.2x
kupuju v IPMEDII a v ASPE, nikde jinde.
michnzee
Příspěvekod michnzee » 11 years ago
Mě se upgrade líbí :) zkusil jsem ho nahodit jak mě to napadlo a všechno zatím funguje.
Co je fajn - konečně se nelogují zprávy o přihlašování / odhlašování mobilů na wifi - neustálý problém tapetování, dále se mi líbí vyřešení problémů u tunelů. Jinak úplně nevím v čem byl revoluční upgrade toho fastracku, přidání pravidel, někde se mi to načítá a někde ne. Uvidíme časem 8)
michnzee píše:Co je fajn - konečně se nelogují zprávy o přihlašování / odhlašování mobilů na wifi
Jak nelogují? Ted jsem to nahodil na rb532 kterou mám jako wifi doma a mobily se normálně v logu jsou
asimyslel logování když se wifina uspí..
pajas
Příspěvekod pajas » 11 years ago
tak jsem dnes nasadil 6.30 na jeden bod, RB750r2, RB Metal, RB Groove, OmniTik a vše šlape parádně, propustnost na spojích drží jak víno, je to tedy celkem mimo rušení
ať se daří!
iTomB
Příspěvekod iTomB » 11 years ago
Nefunkcni NS2. Spoj je spojen, je videt druha strana v /ip neighbor, ale ping neprojde ...
Zmena balicku na CM2 nepomohla. Downgrade smazal nastaveni NS2 a radii.
iTomB
iTomB píše:Nefunkcni NS2. Spoj je spojen, je videt druha strana v /ip neighbor, ale ping neprojde ...
iTomB
něco podobného. 711-ka L4 jako AP, po upgrade na 6.30 vše OK, po několika hodinách vzroste ztrátovost do ETH na cca 70 proc., po dlouhém boji se podařil restart, pak dočasně vše OK. Po pár hodinách opět velká ztrátovost a tak dokolečka.
Po návratu na 6.28 vše OK a problém se již neobjevil.
mpcz, 29.07.2015
Je pravda že 6.30 jsem snad nikde nedal. Ale na 6.30.1 a 6.30.2 nic podobného na rb711 nepozoruji
hmm tohle se mi děje jednou za čas všude kde mám 6.19+ je to fakt jednou za dlouhý čas, mám dojem že to souvisí s nějakou úpravou co byla od nějaké verze 6.10 kdy všechny boardy prostě začaly malinko mít PL...
Mino
Příspěvekod Mino » 11 years ago
Na RB711 pri 6.30 mi isiel ethernet iba na 10Mb, po aktualizacii na 6.32 uz je opat na 100Mb
