Problem s dvoma mikrotik RB2011UiAS-2HnD-IN v ISP public sieti.
sajdo
Příspěvekod sajdo » 11 years ago
Zdravim vsetkych. Potreboval by som poradit. Mam 2 RB2011UiAS-2HnD-IN routre v jednej ISP /24 public sieti.
Problemom je velky packet loss a TCP retransmission.
Router01 - 213.xxx.yyy.24
Router02 - 213.xxx.yyy.19
### ping test z Internetu ###
### Ping test na Router01
pc@pc:~$ ping 213.xxx.yyy.24
PING 213.xxx.yyy.24 (213.xxx.yyy.24) 56(84) bytes of data.
64 bytes from 213.xxx.yyy.24: icmp_req=1 ttl=52 time=245 ms
64 bytes from 213.xxx.yyy.24: icmp_req=2 ttl=52 time=yyy1 ms
64 bytes from 213.xxx.yyy.24: icmp_req=3 ttl=52 time=334 ms
64 bytes from 213.xxx.yyy.24: icmp_req=4 ttl=52 time=252 ms
64 bytes from 213.xxx.yyy.24: icmp_req=5 ttl=52 time=281 ms
64 bytes from 213.xxx.yyy.24: icmp_req=6 ttl=52 time=324 ms
64 bytes from 213.xxx.yyy.24: icmp_req=7 ttl=52 time=262 ms
64 bytes from 213.xxx.yyy.24: icmp_req=8 ttl=52 time=347 ms
64 bytes from 213.xxx.yyy.24: icmp_req=9 ttl=52 time=542 ms
64 bytes from 213.xxx.yyy.24: icmp_req=10 ttl=52 time=yyy1 ms
64 bytes from 213.xxx.yyy.24: icmp_req=11 ttl=52 time=407 ms
64 bytes from 213.xxx.yyy.24: icmp_req=12 ttl=52 time=245 ms
From 213.xxx.yyy.19 icmp_seq=13 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=14 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=15 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=18 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=19 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=20 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=21 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=22 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=23 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=24 Destination Host Unreachable
64 bytes from 213.xxx.yyy.24: icmp_req=27 ttl=52 time=234 ms
From 213.xxx.yyy.19 icmp_seq=25 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=26 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=28 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=29 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=30 Destination Host Unreachable
64 bytes from 213.xxx.yyy.24: icmp_req=32 ttl=52 time=238 ms
From 213.xxx.yyy.19 icmp_seq=31 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=33 Destination Host Unreachable
64 bytes from 213.xxx.yyy.24: icmp_req=35 ttl=52 time=252 ms
From 213.xxx.yyy.19 icmp_seq=34 Destination Host Unreachable
From 213.xxx.yyy.19 icmp_seq=36 Destination Host Unreachable
********* vystup orezany **********
^C
--- 213.xxx.yyy.24 ping statistics ---
83 packets transmitted, 20 received, +59 errors, 75% packet loss, time 82318ms
rtt min/avg/max/mdev = 234.496/403.183/yyy1.928/258.259 ms, pipe 4
### Ping test na Router02
pc@pc:~$ ping 213.xxx.yyy.19
PING 213.xxx.yyy.19 (213.xxx.yyy.19) 56(84) bytes of data.
From 213.xxx.yyy.24 icmp_seq=1 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=2 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=3 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=4 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=33 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=34 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=35 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=36 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=37 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=38 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=39 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=40 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=41 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=42 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=43 Destination Host Unreachable
64 bytes from 213.xxx.yyy.19: icmp_req=44 ttl=52 time=290 ms
From 213.xxx.yyy.24 icmp_seq=45 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=46 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=47 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=74 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=75 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=76 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=77 Destination Host Unreachable
64 bytes from 213.xxx.yyy.19: icmp_req=80 ttl=52 time=69.9 ms
From 213.xxx.yyy.24 icmp_seq=78 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=79 Destination Host Unreachable
64 bytes from 213.xxx.yyy.19: icmp_req=81 ttl=52 time=60.8 ms
64 bytes from 213.xxx.yyy.19: icmp_req=82 ttl=52 time=57.3 ms
64 bytes from 213.xxx.yyy.19: icmp_req=83 ttl=52 time=56.2 ms
64 bytes from 213.xxx.yyy.19: icmp_req=84 ttl=52 time=55.9 ms
From 213.xxx.yyy.24 icmp_seq=85 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=87 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=86 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=88 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=89 Destination Host Unreachable
From 213.xxx.yyy.24 icmp_seq=90 Destination Host Unreachable
^C
--- 213.xxx.yyy.19 ping statistics ---
93 packets transmitted, 6 received, +84 errors, 93% packet loss, time 92352ms
rtt min/avg/max/mdev = 55.908/98.463/290.493/86.011 ms, pipe 4
1. Neviem preco Router02 odpoveda na ping (Destination Host Unreachable) pri teste na Router01 a naopak. Moze to byt chyba v konfigu?
2. Ked nahradim napr. Mikrotik Router01 s Linksys home routerom tak vsetko funguje ako ma, ziadny packet loss alebo TCP retransmission.
Router OS 6.24, firmware 3.19
