5.5.10
Sally
Příspěvekod Sally » 12 years ago
AirOS V Firmware Revision History
Supported products
* NanoBeam M2/M5
* AirGrid M5 HP
* NanoStation M5
* NanoStation M5 Loco
* Rocket M5/Titanium
Version 5.5.10 (XW)- Service release (October 01, 2014)
Regulatory updates:
- New: Open 5150-5250MHz frequency range for United States and Puerto Rico (U.S. territory) countries. This change applies for product models listed bellow:
* NanoStation M5
- New: Add 40MHz channel bandwidth for New Zealand
Fixes:
- Fix: airSync crashes on new Rocket M5 Titanium
- Fix: airView causes device to reboot (US version products)
- Fix: Ethernet negotiation issues when using 100Mbps PoE with gigabit capable devices
- Fix: Remote station management issues on high traffic load (WPA2-AES, WDS)
- Fix: AutoACK miscalculation for 8MHz and 30MHz channel widths
- Fix: Device bricks when using configuration backup file taken from NanoStation device with PoE passthrough option enabled
- Fix: EAP TTLS/PEAP do not check time in TLS sessions
- Fix: Get Last IP from VLAN tagged traffic
- Fix: RADIUS accounting issue
- Fix: Site Survey improvements
- Fix: Don't offer to store WPA PSK key as login credentials
Improvements:
- Low TX issue improvements
- airMax: Improvements for narrow channel widths usage scenarios
- airMax: Improvements addressing Low TX when connecting to XM AP
- Ethernet: 100Mbps negotiation for NanoBeam M5 400 (XW) and Rocket M5 Titanium (XW)
- Data rates: Improved Data Rate selection when connecting to XM devices
placek.milan
Příspěvekod placek.milan » 12 years ago
Ivan Bruna
Příspěvekod Ivan Bruna » 12 years ago
XW verze by nebyla?
placek.milan
Jistě bude zítra, ale přímo v jednotce lze již stáhnout a updatovat...
Porad vynuceny DFS ON a bez moznosti rucne regulovat vykon v plnem rozsahu ? Nebo co to ma jeste na mouchy ? Ty improvments se mi jinak docela libi :wink:
placek.milan
Příspěvekod placek.milan » 11 years ago
http://dl.ubnt.com/firmwares/XW-fw/v5.5 ... 1.1641.bin
DFS lze vypnout změnou Country na Aruba stejně jako v 5.5.9 :wink:
pedro4444
Příspěvekod pedro4444 » 11 years ago
mi pouzivame chile :)
divizna
Příspěvekod divizna » 11 years ago
Spis je problem s stale chybejicim kanalem 5480 v CZ channel listu (osobne jsem jim to nekolikrat reportoval) a obecne s odebranym compliance testem.
DFS nekomentuji, na jeden sektor jsem 5.5.10 nasadil s CZ country (kanal 5600) a ani jeden klient se mi nechtel spojit (cekal jsem 10 minut, dele jsem to nevydrzel). Po tom, co jsem DFS vypnul se najednou lidi spojili.
DFS je peklo ... kdo ví, co se stane, když neví kam přeladit?
Mimochodem mám zprávy, že tomu vadí i přelet Gripenu ... okolo Čáslavi s tím je problém, létají tam už nízko.
Proti těm časům funguje toto:
echo "/usr/sbin/radartool cactime 1000" > /etc/persistent/rc.poststart
echo "/usr/sbin/radartool -i wifi0 usecac 0" >> /etc/persistent/rc.poststart
echo "echo '<option value=\"511\">===Compliance Test===</option>\n' >> /etc/ccodes.inc" >> /etc/persistent/rc.poststart
chmod +x /etc/persistent/rc.poststart
cfgmtd -w -p /etc/
reboot
To lepší řešení compliance testu, co sem nedávno někdo dával jsem ještě nezkoušel ...
vim co se stane, v případě APčka prostě nevysílá a ty se to nedozvíš a klienti se nepřipojí.
Tak preto pouzivame vsade 5.5.6, ziadny lepsi fix sa odvtedy neudial :)
Jenže to je verze XM, tedy něco, co už zanedlouho nekoupíš ... Musíme se naučit žít s verzemi >5.5.9
Kromě toho v 5.5.8 opravovala poměrně důležité chyby.
mmazna
Příspěvekod mmazna » 11 years ago
ludvik píše:Jenže to je verze XM, tedy něco, co už zanedlouho nekoupíš ... Musíme se naučit žít s verzemi >5.5.9
FW XW je i ve verzi 5.5.6
http://www.ats.pl/~kamilk/XW.v5.5.6.188 ... 0.1623.bin
divizna
Problem je, ze u XW je problem s tzv. low tx rate problemem. Zejmena u rocketu titanium, ale treba i u nanobeamu. To zarizeni se bud chvilkove a nebo nastalo sekne na nejnizsi rate, vysledkem je padani spoje, o kterem se ale skoro nedozvis, protoze spoj jede, pingy prochazeji, ale rychlost je realne nekde kolem 3-4 Mbit.
V 5.5.10 to opravili, jenze pak uz nedas compliance test, respektive ho das, ale nesmis hnout s jedinym parametrem - pak uz te to nepusti ulozit, protoze nemas vybranou zemi. Treba zmena kanalu je tak porod. Jde to obejit jistym trikem, ale je to proste opruz na deset minut nejmin.
divizna
Jinak XW uz je skoro vsechno az na rockety, ty budou XW od prosince 2014.
