*) sstp - report TLS encryption as well;
*) safe mode - do not allow user with less permissions to disrupt active safe mode;
*) console - print command does not try to reuse item numbers assigned by previous invocations of 'print' when doing 'print where' or 'print follow', items are numbered consecutively starting from '0'.
*) console - fix compact export of some partially modified configuration values;
*) api - use the same syntax for property values as is used in 'print detail' output, with the exception of numbers, that are not shown with suffixes (K/M/G/T or bitrate) and are not contracted or separated into digit groups, and "yes"/"no" values that continue to be reported as "true"/"false".
*) console - show internal numbers in the form returned by 'find' (like *9A0F) instead of "(unknown)" when configuration refers to deleted items. This change also applies to API.
*) ipsec - fix addition of default policy template;
*) console - values of type 'nil' were returning 'nil' as result of most operations. Now it compares less than all values except 'nil' and 'nothing', and compares inequal to all values except 'nil'. This was changed to make 'print where' and 'find where' more useful. An example. Previously the following command /ip route print where routing-mark!=nosuch Would not print routes that had no value for 'routing-mark' set, because (nil != "nosuch") was equal to nil. Now it evaluates to 'true', and this command will also print all routes that have no 'routing-mark' value set.
*) l2tp - fixed problem on CCR where server responded with wrong source address;
*) console export - put qutes around item names that start with a digit;
*) sntp client - added support for dns lookup of ntp servers;
*) console - when exporting to file, use name ending in '.in_progress', and rename when export finishes;
*) bridge setups sometimes could crash on CCR devices;
*) fixed port flapping in 1G mode on sfp-sfpplus1 on CRS226;
*) fixed SXT ac model losing it's interface if changing regulatory settings in "routerboard" menu
Verze 6.18
Zajímavá featura, že nejdou odinstalovat nepotřebný balíčky pokud je to upgradovaný pomocí Upgrade package
nevíte jeslti už opravili u starších RB ten problém s wireless-fp a hláškou kernel failure?
RB2011: uptime 19 hodín, zatiaľ bez problémov.
Blažej Krajňák
Blažej Krajňák
411, 711, 911, groove, sxt vše zatím OK
UPDATE:
na RB2011 som nasiel CPU nezmyselne na 100%, pritok prietok nebol vacsi ako 1Mbps. Trvalo to asi par minut.
- Screenshot z Winboxu
- rb2011-6.18-cpu.png (85.98 KiB) Zobrazeno 3437 x
Blažej Krajňák
Blažej Krajňák
Tak jsem to skusil na SXT a taky to už nenajelo.
Přes netinstall se mi groove i sxt povedlo znovu rozchodit, ale na dalších to zkoušet nebudu
počkám si na stable 6.19.
Petr Krist
Co s tím děláte? SXT, Groove, rb2011 vše OK. Zatím ani jedno zdechnuté zařízení na 6.18
SXT mi taky nenajelo, ale bylo to z verze 6.17 která vůbec nefungovala dobře takže bych to dával za vinu spíš jí...
No já měl všechno z verze 6.17 Myslíš teda downgrade na 6.16 a pak teprve na 6.18?
Petr Krist
U mna bol RB2011 aj RB433 upgradovaye z 6.17 na 6.18 ... a vsetko zatial zije.
Naposledy upravil(a) eKrajnak dne 04 Aug 2014 21:45, celkem upraveno 1 x.
Blažej Krajňák
Blažej Krajňák
po upgradu u CRS se vyskytl vyšší packet loss - občas, klasickým pingem je to prakticky nezměřitelné...
Ako som včera v noci zistil vďaka contofal-ovy, tak 6.18 má problém, že zhadzuje Winbox. V mojom Deme (home.ekrajnak.com ispforum/ispforum) to je napr. vtedy, ak sa otvorí Wireless -> wlan-ap. Robí to iba pod userom ispforum. Inak admin účet to otvorí normálne. Takže to robí v6.18 asi nepoužiteľnú.
Posielal som to na support@mikrotik.com, tu je Screen record: http://uploads.ekrajnak.com/ros6.18-bug ... _crash.avi
Blažej Krajňák
Blažej Krajňák
když jsem aktualizoval z 6.15 na 6.18 s FP balíčkem tak to napsalo následující blaboly v logu
