We are happy to announce 802.11ac support in RouterOS. Before we make this a general release, we would like to give you the ability to test it first.
802.11ac support is enabled for QC9880/9882 wireless chipsets, and wireless-fp package must be used. It is included in the general combined package, no separate download necessary.
What's new in 6.16rc15 (2014-Jul-08 10:45):
*) l2tp server: added option to enable IPsec automatically;
*) poe-out: added power-cycle-ping and power-cycle-interval settings;
*) gps - increased retry duration to 30 seconds;
*) time - on routerboards, current time is saved in configuration on reboot and on clock adjustment, and is used to set initial time after reboot;
*) sntp - disabling/enabling client was causing dynamic-servers to be ignored (bug introduced in 6.14);
*) tilera - improved handling of bad blocks in nand;
*) ipsec - allow multiple encryption algorithms per peer;
*) email - support tls only connections;
*) smb - fixed usb share issues after reboot
*) snmp - fix v3 protocol time window checks;
*) updated timezone information;
*) quickset - added VPN settings for HomeAP mode;
Mikrotik podpora 802.11ac + nové MK produkty
Naposledy upravil(a) honzam dne 13 Jul 2014 09:34, celkem upraveno 2 x.
RB921-5SHPacT
https://apps.fcc.gov/oetcf/eas/reports/ ... 21-5SHPACT
SXTG-5HacD
https://apps.fcc.gov/oetcf/eas/reports/ ... SXTG-5HACD
SXTG-5HacD-SA
RBCM2N (cAP-2n)
https://apps.fcc.gov/oetcf/eas/reports/ ... =TV7RBCM2N
fotky uvnitř odkazů
SXTG-5HacD
SXTG-5HacD-SA
RBCM2N (cAP-2n)
fotky uvnitř odkazů
Naposledy upravil(a) honzam dne 08 Jul 2014 19:27, celkem upraveno 3 x.
http://pojitko.cz
http://pojitko.cz
Nejvíc se mě líbí rb921, mělo by být více modelů v nabídce:
There are four models available – two Three-chain devices (with miniPCIe slot and without), and two Dual-chain models (with miniPCIe slot and without). Extra places for more RP-SMA connectors are available on the unit in this case
- ac.jpg (118.49 KiB) Zobrazeno 4922 x
tak to je super hlavně se mě libi ta SFP šachta ted už to bude mít smysl tahat optiku až nahoru na stožár a dat zbohem s indukcí
bojim se bojim pevnosti konektoru na anteny...snad je to poradne pripajeno k DPS.
RB921 je peknej ! skoda ze se musi tahat UTPko kvuli napajeni...kdy to sem doputuje ?
pcwifi píše:bojim se bojim pevnosti konektoru na anteny...snad je to poradne pripajeno k DPS.
Bude to v kovovém boxu - koukni na odkaz nahoře. Tim padem nehrozí vylomení
pcwifi píše:RB921 je peknej ! skoda ze se musi tahat UTPko kvuli napajeni...kdy to sem doputuje ?
Podle me bude existovat i verze s jackem. Je tam na to příprava...
Stejně tak se budou dělat verze s MMCX konektorama. Na DPS na to je taky příprava . . .
- Moderátor
RouterBoard SXTG 5HacD
RouterBoard CeilingM 2n
NetMetal 5 s RouterBoard 912GS 5SHPac
Bývalý ISP...
http://www.alternetivo.cz/mikrotik-rout ... 43323.html
sice to není ac ale mohlo by byt dost podobny
by mě zajímal ten zisk anétény u toho SXT, asi to bude dost mizerné že?
- Moderátor
Zisk bude asi stejně jako ted ne ? Anténa se nemění.
Bývalý ISP...
Taky bych řekl, anténa bude to samé. Mění se jen chipset
