Cisco Catalyst webauth
bajk
Příspěvekod bajk » 11 years ago
ahojte, viete mi poradiť, príp. zaslať example config na webauth na radius server z cisco catalyst konkrétne 2960? dot1x mi funguje bez problémov (používam potom aj zaradenie do VLAN podľa LDAP používateľa), ale webauth mi nie a nie fungovať. ďakujem za rady a pomoc
prikladám config:
aaa new-model
aaa authentication login default local
aaa authentication dot1x default group radius
aaa authorization exec default local
aaa authorization network default group radius
aaa authorization auth-proxy default group radius
aaa accounting update newinfo periodic 15
aaa accounting network default start-stop group radius
aaa accounting connection default start-stop group radius
ip device tracking
ip admission name webauth1 proxy http inactivity-time 60
dot1x system-auth-control
ip radius source-interface Vlan92
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 32 include-in-access-req format %h
radius-server dead-criteria tries 2
radius-server host ip adresa auth-port 1812 acct-port 1813
radius-server retransmit 2
radius-server key kluc
radius-server vsa send accounting
radius-server vsa send authentication
interface FastEthernet0/1
 switchport mode access
 authentication event fail action authorize vlan 104
 authentication event no-response action authorize vlan 104
 ip admission webauth1
end
