What's new in 6.9 (2014-Jan-31 11:18):
*) lcd - added option to change the color-scheme;
*) updated bootloader firmware;
*) ppp: fixed RADIUS accounting;
*) ppp: fixed IPV6-Prefix assigning;
*) ppp: fixed dial-on-demand;
What's new in 6.8 (2014-Jan-29 15:52):
*) bridge - default protocol-mode changed to RSTP for new bridges,
fixed bridge mac address changing when port (with lowest mac address) goes down
*) userman - improve startup time;
*) sstp client - support server name verification from certificate;
*) wireless - improved 11n and nv2 stability;
*) dhcp client - support interfaces in bridge;
*) dhcp - parse decimal strings and IP addreses in options value;
*) bgp - don't show community 'internet' in BGP advertisements;
*) ipsec - enable hardware acceleration for aes-cbc + md5|sha1|sha256 aead on tilera cpus;
*) ospf - fixed checksum calculation for OSPFv3 AS-external-LSAs;
*) default configuration - changed dhcp server lease time to 10 minutes;
*) fixed port isolation on CRSs (bug introduced in v6.6);
*) smb - added support for SMB 2.002
*) timezone information updated;
*) ppp - fixed ppp bridging (did not work since v6.6);
*) improved speed of PPP, PPPoE, PPTP & L2TP on multicore routers;
*) address-list - fix crash when adding two identical address list entries (not allowed any more);
*) fixed multicast forwarding on CCRs;
*) firewall - improved address-type matcher, and added it for ipv6 aswell;
Verze 6.9
- hapi
Kysa
Takže CRS125-24G-1S opět žádná změna proti 6.7 Všechny porty běží na 10M. Zůstávám u 6.6
- goblajz
RB2011UAS, RB133, RB433AH, RB411, SXT, SXT Lite, OmniTik, x86 - všechno naběhlo a zatím jede
- Myghael
- michnzee
- pcwifi
v pohode po par hodinach ? poreferuj po mesici...to by se uz vetsina chyb mela projevit
do te doby nasadit na nedulezite prvky v siti... leckde nechavam stale 5.xx , protoze co jede na to se co ? Kurňa Nemaká !
Dalibor Toman
BTW: mam informace od supportu, ze zmeny vedouci ke zvyseni stability NV2 nemaji v umyslu backportovat do rady 5.X. Podle nich uz zmen v 6tkovem wirelessu bylo tolik, ze neni jednoduche je nacpat do 5tkove rady. Pokud nechcete nekdo jeste odpisovat 1xx desky, tak do MT zkuste dloubnout ...
- 3com
Nasazeno na spoj AP RB912 + JRC 24-DuplEX na něj dva Klienti RB911 + JRC 24-DuplEX, 4,5Km, CCQ 100/100, - 59. Zatím ok bez rozpojení. V předešlých verzích se klienti několikrát za den na dvě sekundy odpojili a hned připojili. Viz log
- Mk.png (52.47 KiB) Zobrazeno 4052 x
- honzam
Kysa píše:Takže CRS125-24G-1S opět žádná změna proti 6.7 Všechny porty běží na 10M. Zůstávám u 6.6
To bude nějakej bug u tebe. 6.8 a 6.9 vše OK na CRS. Porty běží na Gigu. Doporučuji ti resetovat konfig, Upgradovat na 6.9 a znovu nastavit.
Dalibor Toman píše:BTW: mam informace od supportu, ze zmeny vedouci ke zvyseni stability NV2 nemaji v umyslu backportovat do rady 5.X. Podle nich uz zmen v 6tkovem wirelessu bylo tolik, ze neni jednoduche je nacpat do 5tkove rady. Pokud nechcete nekdo jeste odpisovat 1xx desky, tak do MT zkuste dloubnout ...
Podle mě bude stačit nechat rb133c s verzí 5.26. Zamrzání podle mě způsoboval problém na AP. A tam snad nikdo MIPSLE nemá. Takže AP 6.9 a old klienty 5.26 a bude to snad cajk
Dalibor Toman
honzam píše:Dalibor Toman píše:BTW: mam informace od supportu, ze zmeny vedouci ke zvyseni stability NV2 nemaji v umyslu backportovat do rady 5.X. Podle nich uz zmen v 6tkovem wirelessu bylo tolik, ze neni jednoduche je nacpat do 5tkove rady. Pokud nechcete nekdo jeste odpisovat 1xx desky, tak do MT zkuste dloubnout ...
informace, co mam ja (od supportu) rikaji, ze problem je zpusoben nejakou chybou na klientskem radiu. Kdyz me naznacovali to same co rikas Ty (upgradovat alespon AP) tak na primy dotaz odpovedel Uldis:
we think that upgrading at least the AP side could improve the stability for you
but we can't guaranty that the lockup could still happen on the client side.
No nic tak uvidime. Uspech bude i to kdyz to zamrzani opravdu zmizi alespon z 6.x klientu.
- honzam
Jasně, pripadne si na těch konkretnich zastaralych 133c klientech nastavíš netwatch. Případně reboot script jednou za čas v noci...
- michnzee
Hele a ještě jedna věc, čeho jsem si všimnul, předtím co jsem měl při běžným provozu využití CPU nějakých 12-15%, tak při obdobném využití mám teď stabilně okolo 3-5%. Je to možný?
Kysa
honzam píše:Kysa píše:Takže CRS125-24G-1S opět žádná změna proti 6.7 Všechny porty běží na 10M. Zůstávám u 6.6
A zkoušels to, nebo jenom věříš tomu, co je v interfaces? Mě to píše rychlost 1G, ale pokud skusím něco stáhnout z druhýho pc, tak je rychlost 1000kb
