Snazim se zprovoznit RB751U 2HnD s ROS 6.4 a AnyDATA ADU-770WH. Je to combo 3G/CDMA modem. Zamerem je, ze budu prevazne pouzivat 3G coby zalohu hlavniho internetoveho pripojeni, ale pokud se budu muset premistit na delsi dobu do 3G nepolibenych oblasti Cech, tak budu odkazan pouze na CDMA pripojeni (neb GPRS neni to prave orechove).
Vcelku bez problemu se mi povedlo rozchodit 3G:
/port
set 0 name=usb1
set 1 name=usb2
/interface ppp-client
add apn=internet comment="UMTS 3G" disabled=no name=ppp-out1_3G password=o2 \
port=usb1 user=o2
/ip firewall nat
add action=masquerade chain=srcnat out-interface=ppp-out1_3G
Pokud ale disabluji port 0 a nahodim port 1 (CDMA), tak se modem zdanlive pripoji, pingy projdou, ale realny provoz zacne generovat nekonecny cyklus odpojovani, pripojovani modemu.
/port
set 0 name=usb1
set 1 name=usb2
add comment=CDMA disabled=no dial-command=ATD dial-on-demand=no name=ppp-out2_CDMA \
password=heslo phone=#777 port=usb2 user=607xxxxxx@o2.cz
/ip firewall nat
add action=masquerade chain=srcnat out-interface=ppp-out2_CDMA
Laborovani s Data a Info channel je patrne zbytecne, protoze se pripojim pouze s obema hodnotami nastavenymi na 0. Podeziram chybejici modem-init, ale nebyl jsem schopen zatim nikde dohledat, co by se tomuto modemu libilo.
A jeste ten log:
[admin@MikroTik] /log> print
14:27:16 async,ppp,info ppp-out2_CDMA: authenticated
14:27:17 async,ppp,info ppp-out2_CDMA: connected
14:27:17 system,info dns changed
14:27:18 system,info dns changed
14:27:18 async,ppp,info ppp-out2_CDMA: authenticated
14:27:19 async,ppp,info ppp-out2_CDMA: connected
14:27:19 system,info dns changed
14:27:20 async,ppp,info ppp-out2_CDMA: terminating...
14:27:20 async,ppp,info ppp-out2_CDMA: disconnected
14:27:20 async,ppp,info ppp-out2_CDMA: initializing...
14:27:20 async,ppp,info ppp-out2_CDMA: reseting link...
14:27:20 system,info dns changed
14:27:21 async,ppp,info ppp-out2_CDMA: terminating... - modem hunged up
14:27:21 async,ppp,info ppp-out2_CDMA: disconnected
14:27:21 async,ppp,info ppp-out2_CDMA: initializing...
14:27:21 async,ppp,info ppp-out2_CDMA: reseting link...
14:27:22 async,ppp,info ppp-out2_CDMA: initializing modem...
14:27:23 async,ppp,info ppp-out2_CDMA: dialing out...
14:27:24 async,ppp,info ppp-out2_CDMA: authenticated
14:27:24 async,ppp,info ppp-out2_CDMA: connected
14:27:24 system,info dns changed
14:27:30 system,info dns changed
14:27:30 async,ppp,info ppp-out2_CDMA: authenticated
14:27:30 async,ppp,info ppp-out2_CDMA: connected
14:27:32 async,ppp,info ppp-out2_CDMA: terminating...
14:27:32 async,ppp,info ppp-out2_CDMA: disconnected
14:27:32 async,ppp,info ppp-out2_CDMA: initializing...
14:27:32 system,info dns changed
14:27:32 async,ppp,info ppp-out2_CDMA: reseting link...
14:27:33 async,ppp,info ppp-out2_CDMA: terminating... - modem hunged up
14:27:33 async,ppp,info ppp-out2_CDMA: disconnected
14:27:33 async,ppp,info ppp-out2_CDMA: initializing...
14:27:33 async,ppp,info ppp-out2_CDMA: reseting link...
14:27:34 async,ppp,info ppp-out2_CDMA: initializing modem...
14:27:35 async,ppp,info ppp-out2_CDMA: dialing out...
14:27:36 async,ppp,info ppp-out2_CDMA: authenticated
14:27:36 async,ppp,info ppp-out2_CDMA: connected
14:27:36 system,info dns changed
14:27:40 system,info dns changed
14:27:40 async,ppp,info ppp-out2_CDMA: authenticated
14:27:40 async,ppp,info ppp-out2_CDMA: connected
14:27:41 async,ppp,info ppp-out2_CDMA: terminating...
14:27:41 async,ppp,info ppp-out2_CDMA: disconnected
14:27:41 async,ppp,info ppp-out2_CDMA: initializing...
14:27:41 async,ppp,info ppp-out2_CDMA: reseting link...
14:27:41 system,info dns changed
14:27:42 async,ppp,info ppp-out2_CDMA: terminating... - modem hunged up
14:27:42 async,ppp,info ppp-out2_CDMA: disconnected
14:27:42 async,ppp,info ppp-out2_CDMA: initializing...
14:27:42 async,ppp,info ppp-out2_CDMA: reseting link...
14:27:43 async,ppp,info ppp-out2_CDMA: initializing modem...
14:27:44 async,ppp,info ppp-out2_CDMA: dialing out...
14:27:45 async,ppp,info ppp-out2_CDMA: authenticated
14:27:45 async,ppp,info ppp-out2_CDMA: connected
14:27:45 system,info dns changed
14:27:47 system,info dns changed
14:27:47 async,ppp,info ppp-out2_CDMA: authenticated
14:27:47 async,ppp,info ppp-out2_CDMA: connected
14:27:49 async,ppp,info ppp-out2_CDMA: terminating...
14:27:49 system,info dns changed
14:27:49 async,ppp,info ppp-out2_CDMA: disconnected
14:27:49 async,ppp,info ppp-out2_CDMA: initializing...
14:27:49 async,ppp,info ppp-out2_CDMA: reseting link...
14:27:50 async,ppp,info ppp-out2_CDMA: terminating... - modem hunged up
14:27:50 async,ppp,info ppp-out2_CDMA: disconnected
14:27:50 async,ppp,info ppp-out2_CDMA: initializing...
14:27:50 async,ppp,info ppp-out2_CDMA: reseting link...
14:27:51 async,ppp,info ppp-out2_CDMA: initializing modem...
14:27:52 async,ppp,info ppp-out2_CDMA: dialing out...
14:27:53 async,ppp,info ppp-out2_CDMA: authenticated
14:27:53 async,ppp,info ppp-out2_CDMA: connected
14:27:53 system,info dns changed
14:27:54 system,info dns changed
Diky za jakekoliv nakopnuti spravnym smerem.
CDMA modem a RB s USB
V podstatě to máš asi dobře. Že se to při dalších pokusech o spojení kousne bude možná tím, že to RB neumí udělat korektní reset USB. Na RB433UAH se mi to chovalo stejně. Po zapnutí do napájení modemu a RB to šlo 1x, pak kousnutí.
Že ti spadne navázané PPP spojení po pár sekundách bude asi tím, že O2 má striktní kontrolu zdrojových adres v paketech na CDMA, jakmile do té linky pošlel jediný paket, kde zdrojová IP není ti přidělená, tak ti spojení shodí (a to se RBčku občas povede).
Aha, tak s tím USB reset bych to chápal. Uvidíme, až jednou spadne 3G část, to by pak mělo udělat to samé.
A popravdě mi teď dává logiku i to, že pokud tam nic neroutuju, tak mi pingy přímo z RB konzole šlapou jako víno, ale jakmile tam naroutuji vše, tak, jak píšeš, projde tam nějaký "ze strany o2 neočekávaný" paket a shodí to. To by mne zajímalo, jestli bych tomu nechtěnému paketu mohl zabránit vhodně zvolenými pravidly. No asi se bez zachytávání provozu (nebo logování) neobejdu. Každopádně je to posun vpřed, díky.
Jéžiš, já jsem trotl. Ještě že jsem to napsal do "Začátečnického tématu", jinak bych se hanbou propadl
Ono je sice hezké, že jsem si nahodil jiný port (přehodil 3G na CDMA), ale jaksi nebyli lidi na změnu rozhraní v NAT pravidle pro maškarádu po opakovaném přehození z 3G na CDMA. Že bych si tam dal dvě maškarády, to mne v tu chvíli nenapadlo. Takže jsem tam vesele routoval interní rozsah. No to se nedivím, že se to O2 nelíbilo a zabíjeli mne.
Aspoň jsem se opět přesvědčil, že zatímco na Windows vychází jakákoliv snaha o logování čehokoliv vniveč, na Mikrotiku to k něčemu je - uviděl jsem hned, co to tam posílám za blbosti. Díky za potřebné nakopnutí.
Takže - Problem solved. Chyba byla mezi klávesnicí a židlí.
mám také CDMA modem od 02, nakonfigurovany stejne jako rdol, a chova se uplne stejne, vzdy po pripojeni, ziska adressu, projde par pingu, a po chvili nastane nekonecny proces resetovani. Kdyz si udelam maskaradu tak pada temer okamzite po jakemkoli datovem vytizeni. V mikrotiku(bez maskarady) dokaze alespon chvili pingat nez se zhrouti.
Nemate jeste nejakej tuseni cim by to mohlo byt? Mam RB 411u a potreboval bych to celkem nutne rozchodit.
Mockrat dekuji za jakoukoli radu
