Verze 6.1
Verze 6.1
What's new in 6.1 (2013-Jun-12 11:50):
*) pptp, l2tp - fixed crash when tunnel mru was too big and fragmented ip packet was received;
*) hotspot - fixed problem when after upgrade hotspot html directory was empty;
*) ipv6 nd - dns dynamic-servers were not included in router advertisements;
*) winbox - fixed problem Switch menu disappeared on RB2011;
*) fixed memory amount issue on RB1100AHx2;
*) console - '/import' prints each command that is executed;
*) console - 'import' has new argument 'from-line' that starts executing commands after specified line;
*) secure api - fixed problem when wrong client ip address was reported;
*) hotspot - fixed universal client;
*) api - added support for API over TLS (SSL);
*) api - api service is now enabled by default;
*) ppp - do not show R flag for locally authenticated users;
*) vrrp - fixed ah authentication;
*) webfig - added support for RADIUS authentication (via MS-CHAPv2);
*) ipsec - for peers with full IP address specified system will autostart ISAKMP SA negotiation;
*) trafficgen - added inject-pcap command for replaying pcap files into network;
*) dns - retry queries with tcp if truncated results received;
*) improved queue statistics updating;
*) fix 1G linking with some Cisco devices (affects RB7xx, RB9xx, RB1100, RB2011, CCR);
losos
Příspěvekod losos » 13 years ago
aj keby hned nefungovalo nv2, nstream, cely wireless a ipv4/v6 tak za toto maju plus. som neveril ze sa toho dockam, a prekvapipov to aj funguje :shock:
máme přece winbox, tohle neni plus.
Normis nezapoměl zamachrovat:
All reported issues are fixed is 6.1
Kaja
Příspěvekod Kaja » 13 years ago
Jaky mate nazor na tohle: "fix 1G linking with some Cisco devices (affects RB7xx, RB9xx, RB1100, RB2011, CCR)"
Myslite ze to bude resit problemy s 1G linkem i na jina zarizeni nez CISCO?
Treba vecne probelmy se slinkovanim se s pojitky (Ceragon, ALCOMA, RAY...)
K.
nasazeno rb 600, 800, omnitik, rb711, rb 2011,rb 912 a vsude instal v pohode nabehlo bez problema
goblajz
Příspěvekod goblajz » 13 years ago
Žeby u MikroTiku s verzí 6.1 přišla i nová verze stránek?
http://www.mikrotik.com/ momentálně nedostupné.
Nebo maj v cestě CCR a lidi zběsile začli tahat novou verzi? :-D
To už je dnes podruhé. Hostují to někde v cloudu Amazon
hmmm porad nedostupny ....
už jedou
sem tu před několika týdny říkal "co udělá ten jejich updatovací server až se na to sesypou tou novou updadovací funkcí". No co, zpět o 5 let. Trotlové.
Dalibor Toman
Příspěvekod Dalibor Toman » 13 years ago
DD,
btw zkousel jste nekdo uz na ROS6.1 import nejakeho skriptu s cfg pomoci /import? Nejaka chytra hlava vymyslela, ze se ted bude vypisovat cislo a obsah kazdeho radku, ktery se importuje. Takze pokud si v tom CFG skriptu vypisujete nejake pekne informace tak se zcela ztrati v zaplave tech debug printu. No a pokud dojde k syntax chybe tak vlastni hlaseni vypisuje cislo radku 1 takze bez debug printu je k nicemu.
A aby toho nebylo malo tak ten import nefunguje - protoze to vypada, ze bere kazdou radku totalne separatne, takze promenna nadefinovana o 2 radky drive neni pouzitelna. Stejny kod nacpany do /system script se chova spravne...
update: MT support rika, ze se v /import vykonava kazdy radek separatne. Bylo mi doporuceno zapouzdrit cely skript do {}. Vysledek je, ze na cca 5 minut RB2011 bezi na 100% nez prechrousta tech 1800 radku :-(. No a pak to vypise cely zdrojak a teprve pak zacne neco smysluplneho delat. Holt pokrok je pokrok. Tak jsem se jim pokusil vysvetlit, ze by nebylo od veci nepokouset se za kazdou cenu zmenit/rozbit, co roky funguje a bylo mi odepsano, ze se s tim pokusi neco udelat. Uz ted jsem napjaty.
no já jsem zkoušel import nastavení z verze 5 a korektně neprošel protože zase trochu někde změnili syntaxi.... mamlasové
Noxus28
Příspěvekod Noxus28 » 13 years ago
Tak nejaký odvážlivec čo to posadil aj na CCR? ohlasi? U nás na x86 zatial od piatku všetko ok až na ten zber v RAM :(
Repkins
DHCP klient na wlan interface v režimu station bridge prostě nedostane IP adresu. Pokud je DHCP klient na bridge, tak IP dostane, ale to je mě ouplně naprd, páč MAC bridge je jiná než MAC wlan interface. A ISPAdmin umí do DHCP zapisovat jen MAC wlan iface. Taky mě to po upgradu z 5.25 ukazuje horší signál a CCQ.
