Verze 5.21
Verze 5.21
http://www.mikrotik.com/download
changelog doplním až bude na stránkách
Polk
Příspěvekod Polk » 13 years ago
What's new in 5.21 (2012-Oct-12 08:25):
*) route - fix dst-prefix filtering did not return routes when routes with
different routing-mark were present;
*) wireless - improved nv2 stability;
*) winbox & webfig - added simple new version downloading & upgrading panel;
*) dhcp server - immediately store to disk changes for lease configuration;
*) lcd - improve graphs screen
*) lcd - improve touch screen (must /lcd reset-calibration)
*) smb - fix smb share mounting on linux systems
*) ovpn - fixed memory leak on disconnects;
*) userman - fix unpaid profile activation while authenticating;
*) sstp - fix high CPU usage on SSL handshake;
*) winbox - added ability to add time & date to dashboard;
*) metarouter - fixed lockups on RB110AH;
*) metarouter - fixed occasional lockups on RB450G;
*) ups - fixed problem connecting to USB device, introduced in 5.20;
*) quickset - added Wireless PTP Bridge mode;
*) fix MPLS MTU configuration usage;
*) dns - fix empty response;
Jdu na to a uvidime tu stabilitu , minulej tejdne sem udelal spoj a je znacne nestabilni i kdzy nechapu proc , oproti predchozim nema nic jineho a stejne se obcas rozpoji ....
hmmm to bude ten stejnej balík jak, v té 5.20, tedy ten vylepšený
nicméně čekal jsem něco jako "* fix TCP performanece on NV2" :D
Tak bezi na RB800 a omnitik a zatim bez problema , u omnitika hlasi fw 3.0 u rb 800 stale 2.39
zahryzlo mi to jednu rb411(bios 2.38) po upgrade uz nenabehla, nutno odpojit ze stavy na tvrdo. U jedne 112tky ( bios 2.18) mi to vydusilo po upgrade a nasledovnem nastartovani CPU na max. a do RB se v podstate nedalo rozume dostat... pet pomohlo vyp/zap natvrdo. RB711 & 532 prezily upgrade bez problemu. Na RB711 nova verze biosu 3.0. Po zkusenosti to uz na zadnou RB411/112/133 zatim srat nebudu...
u mě upgrade 711, 411, 433, 133 vše OK.
RB133c tam je trošku problém ale spíš s tím že je málo RAM. Po upgrade z 3.30 na 5.21 zůstává 2500kbit RAM volné a to je fakt málo. Chce to povypínat nepotřebné balíčky, hlavně routing, mpls, hospot, ....
Pak si vyčkat na reboot který ne a ne se dostavit :) a po rebootu máme volných 3400kbit RAM a funkční routerboard
Nemáte u toho někdo UPSku na RS232? Už jim to funguje?
Co se tyec nv2 stabily tak jedinej spoj kterej zlobil tak po nasazeni 5.21 od vecrejsiho vecera ani jeden rozpad :wink:
gsmsoft
Příspěvekod gsmsoft » 13 years ago
PC/X86 setko prebehlo bez problemu zatial slape 20h.RB450G ties bez problemu.Dam vediet keby nieco sa ukaze
ludvik píše:Nemáte u toho někdo UPSku na RS232? Už jim to funguje?
Mám USB, v 5.20 nejela, tady jede.
doktor
Příspěvekod doktor » 13 years ago
Tak to funguje i se seriovou UPSkou, 3x hura
Příspěvekod aliney » 13 years ago
Libi se mi vlastnost, ze u klienta nejsou videt nastaveni, ktera nic nezmeni a rozhoduje o nich AP a naopak.
Napriklad "Periodic calibration" v AP modu neni, u station je visible.
rado3105
Příspěvekod rado3105 » 13 years ago
http://forum.mikrotik.com/viewtopic.php?f=7&t=66393
tuto sa stazuju na vysoke latencie....uvidim dnes vecer to nahodim....
tak presne takovou latenci jako ma on na screenu jsem mel taky (OmniTik v mene zarusene oblasti, 21 klientu, mix A/N, vsichni super signaly). ze zacatku, kdyz se klienti pripojili tak cca. 2 minuty hruza ta latence a po chvili uz byla normalni a vse jelo OK.. Tak nevim... Jinak bw test v TCP na Acku cca. 23Mbit.. v Nku asi 60Mbit...
