Zkoušel jsem rovnou nahrát na jeden spoj (Beam AC400 vs Beam AC400) a hned se mi protistrana po výběru country-codu po přefleshi sekla. Pomohlo až reboot z trafa, tak uplně nevim jestli to byl bug nebo feature
Change log tu:
8.5.0 (XC, WA, 2XC, 2WA) Changelog / January 19, 2018
New:
- New: IPv6 support
- New: TDD Framing/GPS Sync support for AirMAX 2AC and M2 devices (2AC AP required)
- New: airLink map view on Dashboard (An embedded airLink map view of the wireless link will be displayed on the dashboard when each AirMAX device has its coordinates configured. This view is toggle-able.)
- New: PPPoE Relay support
- New: OpenSSL update to v1.0.2m
- New: Downgrade below v8.2.0 is not allowed in a single step; to downgrade below v8.2.0, users must first load v8.2.0 and then can downgrade if needed.
Regulatory updates:
- Remove 5.8GHz band for BFWA member states
Removed for BE, BG, HR, CY, IE, LU, MT, NL, PL, SK, SE
- airMAX-ac FF: Improved handling of unregistered multicast traffic
- airMAX-ac FF: Station stops passing data
- airMAX-ac FF: airMAX statistics loss after stations reconnect in large PtMP network
- airMAX-ac FF: Stability fixes
- airOS stability improvements
- Fix: Multiple ports support in Port Forwarding rules
- Fix: Dynamic DNS Client does not update on IP change
- Fix: RX signal reporting in PtMP mode when signal is weak
- Fix: High lighttpd memory usage when airView is running
- Fix: Sometimes station can't connect to AP when seeing many APs around
- Fix: Changes are not saved when clicking Apply immediately after Test Changes
- Fix: Restrict UPnP to >=1024 ports
- WEB UI: Dashboard visual improvements
- WEB UI: Rename TX to RX for remote device on Dashboard
- WEB UI: Core web backend changes (web login flow has changed as part of these changes, so automated scripts using the web backend might stop working)
- WEB UI: Show link distance on Dashboard in miles for United States & United Kingdom and in km for other countries
- WEB UI: Show warning in case signal is too strong (above -20dBm)
- WEB UI: Reduce excessive warnings when Management Radio is disabled
- WEB UI: DHCP Option 82 setting can not be disabled in isolated case
- WEB UI: airView data rendering improvements
- WEB UI: Ethernet port status reporting issues
- WEB UI: Fixed firmware version [object Object] in the Station List
- WEB UI: Site Survey scrolling issue on iOS
- WEB UI: Issue enabling/disabling port forwarding rules
- WEB UI: Wrong reporting of remote GPS coordinates
- WEB UI: Various small UI improvements
8.5.0
Vypnutie DFS
Neberie zmenu country code cez:
sed -i 's/countrycode=.*/countrycode=5000/g' /tmp/system.cfg
save
echo "echo '<option value=\"5000\">Compliance Test</option>\n<option value=\"703\">Slovak Republic</option>' >> /etc/ccodes.inc" > /etc/persistent/rc.poststart
chmod +x /etc/persistent/rc.poststart
cfgmtd -w -p /etc/
reboot
"ccodes.inc" som tam uz ani nenasiel.
ma niekto nejake riesenie?
save
cfgmtd -w -p /etc/
reboot
Už delší dobu při změně country code nedochází k vypnutí DFS, proto je třeba upravit také řádek:
na
Je to zhruba uprostřed mezi oběma místy, na kterých je v konfiguráku country code.
radio.1.dfs.status=enabled
na
radio.1.dfs.status=disabled
Si vis pacem, para bellum.
Velice jednoduše, po úpravě konfiguráku je třeba konfiguraci zapsat a jednotku rebootovat, aby se změny projevily:
Jelikož jednotky po nabootování mají nejprve čekat (DFS Wait), tak se to pozná podle toho, že jednotka při přihlášení nepíše DFS Wait, ale už vysílá.
cfgmtd -w /etc
reboot
- midnight_man
511 je odjakziva
mate s tym problem pretoze compliance robite uplne zle....
na poriadok sa to robí takto:
SSH:
touch /etc/persistent/ct
save
reboot
následne stiahnut konfigurak .cfg
na 2 miestach v konfiguraku zmenit "country code" na 511
uploadnut naspet!!!
takyto compliance funguje aj po upgrade na 8.5.0, fungoval doteraz..aj na starych M5tkach..
SSH:
save
reboot
uploadnut naspet!!!
Zdravim, pokusal som sa upravit configurak, klasicky ako inokedy na nizsich verziach.
Stiahnem, upravim, dam upload config, vyberiem spravny subor a dostanem toto :
Warning
Error parsing firmware version in uploaded config.
Dokonca, aj pokial nic nezmenim v configu (len ho otvorim a dam save) tak to nezoberie.
Edit robim v klasickom WordPade. Na verziach napr 8.3.1 funguje v poriadku.
Nestretol sa s tym niekto? Ze by to kontrolovalo nejaky MD5 sucet ? Google zatial mlci...
Antena PBE-5AC-300-ISO, povodna nejaka v7.x.x, priami upgrade cez ponuku.
Vdaka
Warning
Vdaka
- midnight_man
