8.3.x
SpeedyGT
8.3.x
Příspěvekod SpeedyGT » 9 years ago
Nová verze UBNT FW pro ACečka, tu je change log:
Version 8.3.0 (XC, WA) Release (June 16, 2017)
New:
- New: GPS Sync support for airMAX AC
- New: Secondary SSID support on Station mode
- New: Auto-channel width selection on Station if the APs channel width is changed
- New: UNMS (Ubiquiti Networks Management System) support
- New: Kick All in Station List for reconnecting all stations from AP
- New: Add Speed Test quick launch button to station list
- New: Remember Credentials For This Session setting for saving User Name and Password in Speed Test tool
- New: Enhanced password change validation for security purposes
Fixes:
- Fix: Sometimes Site Survey shows no results on Station (PTP mode)
WEB UI:
- WEB UI: Show UNMS status and last connection time for Local Device on Dashboard
- WEB UI: Show the tooltip for truncated long device name on Dashboard
- WEB UI: Indication of combined signal on Dashboard when signal difference per chain exceeds recommended maximum of 5 dBm
- WEB UI: Show values in Capacity/Throughput and Signal, Noise & Interference chart legends
- WEB UI: Open Tools menu in front of all other windows
- WEB UI: Invalid parameters error in Speed Test when specifying IP manually
- WEB UI: Dashboard graphs are redrawn when a new Station is connected
- WEB UI: Fixed Distance reporting on Dashboard
- WEB UI: airView scrollbar issue
Naposledy upravil(a) SpeedyGT dne 03 Sep 2017 12:37, celkem upraveno 1 x.
Myghael
Příspěvekod Myghael » 9 years ago
Kdyby raději opravili bugy předchozích verzí, ach jo. 8.3.2 by mohla být stabilnější? :D
nechtej
Příspěvekod nechtej » 9 years ago
Jaký bugy máš na mysli?
forkman
Příspěvekod forkman » 9 years ago
Mám nasazeno na test, 2 dny a zatím ok. Jede přes to pppoe session, takže žádné výpadky. Líbí se mi, že speedtest už je konečně použitelný☺
Taky by mě zajímalo co je tam za bugy.
miko
Příspěvekod miko » 9 years ago
Nečteš a nevíš :)
https://community.ubnt.com/t5/airMAX-GP ... X_GPS_Sync
onedlho bude 8.3.x, kde okrem ineho bude aj tychto zopar znamych chyb opravenych....
DarkLogic
Docela otravné je, že je zpřísněná politika zadávání hesel, takže nejde změnit heslo, pokud nebude splňovat následující:
The password must have 8 or more characters with at least one character from each of these groups: lowercase (a-z), uppercase (A-Z), number (0-9) and special character (!@#$%^&*). Alternatively, use a passphrase of 20 or more characters.
dubrma
Příspěvekod dubrma » 9 years ago
Pamatuji dobu, kdy jsem kvůli UBNT zkracoval hesla a teď je mám prodlužovat?
Ispič
Příspěvekod Ispič » 9 years ago
Buď su slepý, nebo někam zmizeli konstelační diagramy, airmagic píše jen "shromažďování dat" ale nic dál se neděje
nechtej
U mě normálně funkční
Ispič
Mě to nefakčí, zkoušel sem to i na druhém komplu. Airmagic pořád načítá a načítá. Konstelační diagramy tam taky prostě nejsou :) nechápu, asi su lama ;)
asi nic neztratíš, když tam narveš 8.3.1
Ispič píše:Buď su slepý, nebo někam zmizeli konstelační diagramy, airmagic píše jen "shromažďování dat" ale nic dál se neděje
si slepy
Ispič
Stačilo napsat hledej šmudlo v menu nahoře ;)
Po přehrátí 8.3.1 začal Airmagic fungovat.
Díky za rady
miko
ani sme sa nenazdali, a 8.3.2 tu bude hned. Beta je uz na svete.....
Ani som nestihol upgrade na 8.3.1, prisiel som o nieco? :)
Ispič
S 8.3.0 a 8.3.1 se mi po několika hodinách snížila propustnost na řádově megabity. Po restartu vždy nějakou dobu v pořádku. Po přehrátí na 8.1 se to za několik dní nestalo ani jednou. Počkám na další verzi.
