Na 4.X uz nejak prdi....
What's new in 5.0beta5 (2010-Jul-23 14:50):
*) email - supports multiple CCs
*) fix 5&10MHz channel support for 11n cards;
*) ssh - fix ssh client crash;
*) ssh - password authentication is disabled for users with public keys;
*) ping - fixed ping packet-loss calculation;
Verze 5.0beta5
In RouterOS v5.0beta5 there is a new wireless protocol Nv2 which is based on the TDMA.
To make the connection using Nv2 on the AP side you need to select the wireless-protocol=nv2 and on the Station side you can also select wireless-protocol 'nv2' or 'any'.
Some features are not ready yet for Nv2: no support WDS,Security,Virtual AP,some details in the registration table and status. We will optimize the Nv2 in the upcoming versions.
We would like to get some feedback from you how it is working on your wireless links. When posting, please include info on the distance of the link and settings that you have and latency.
When testing N link with Nv2 you can get approx 97Mbps UDP traffic and 94Mbs TCP traffic through RB711 in one direction using one chain.
nv2 is not compatible with Airmax.
nv2 is supported for all Atheros cards, except old AR5211 based, so in order to try it out it is not required to have 11n cards - just upgrade, set wireless-protocol=any on station (this will enable station to look for whatever protocol AP that is available with appropriate SSID), set wireless-protocol=nv2 on AP and you are ready to go. If something goes wrong change wireless-protocol on AP to nstreme/802.11 - whatever you were using before.
If "Time Synch" means some synchronization between APs, then no, nv2 does not support such feature yet. You can think of it as of improved nstreme. Its benefits are intended to come from removed polling overhead.
- lwq
honzam píše:Na 4.X uz nejak prdi.... ...
Jenze kdy tedy bude 4.x stable, aby se dala poradne pouzit ?
nikdy. Předpokládal jsem, že v4 bude slepá a rychlá, pouze k rozchození Nkových karet a změnu licenční politiky tak aby setřásly cracknutý verze.
vzhledem k tomu ze 4.10 vysla na konci kvetna a od te doby nic. Mezi tim vyslo nekolik 5.x beta ROS. Tak si myslim ze mozna budeme brzo prechazet na 5.X
honzam píše:vzhledem k tomu ze 4.10 vysla na konci kvetna a od te doby nic. Mezi tim vyslo nekolik 5.x beta ROS. Tak si myslim ze mozna budeme brzo prechazet na 5.X
mame 4.11 tak jsem se mozna spletl
- lwq
honzam píše:mame 4.11 tak jsem se mozna spletl
Ale jen mooozna Kazdopadne 5.x je sympaticka, ale - to na provoz neni ani nahodou. Vlastne ani na nestovani sem se jeste neodvazil zapracovat
hapi píše:nikdy. Předpokládal jsem, že v4 bude slepá a rychlá, pouze k rozchození Nkových karet a změnu licenční politiky tak aby setřásly cracknutý verze.
mno vidis, a kdyz jsem zacal jejich "stable" verze oznacovat za v4.0betaXX, tak jsem se schledal jen s kritikou ,
az od MKv3.10 se to da povazovat za stable verzi , z toho az k MKv3.30 je tak 5 realne stable (+-bus)
a doposud tvrdim ze jejich v4.11 by se mela v realu oznacovat jako v4.0beta11
V4 je jen vynucena zmeny licencni politice, protoze je to od v3.22 cracknuty
proc (i kdyz nikdy nerikej nikdy), neni v4 cracknuta ?
.... protoze se asi do toho nikomu moc nechce
a pokud by jde stable V5 pouzitelna?
rekl bych az tak bude jejich stable verze v5.10 vydana, najde se opet nekdo kdo to vyhakuje (dejme tomu ve v5.20)
co prijde potom v6 a nasledna zmane licenci ?? ... atd atd
hmm, proč ne. 4.10 a 4.11 je použitelná verze fungující spolehlivě. Nepočítám nespolehlivost Nkových karet. Mám jí na jednom důležitym routeru v síti a je bez problemu. Jenom jsem poukazoval již dřív že se mi to zdá podivný a rychlej příchod v5 a prodloužení licencí napovídal jenom o urychlení konce v4. Jistě sis všimnul že licenční kod doznal většího rozměru a možná i jinýho algoritmu a dá se předpokládat, že cracknutí bude složitější záležitostí.
