What's new in 6.45.2 (2019-Jul-17 10:04):
*) bonding - fixed bonding running status after reboot when using other bonds as slave interfaces (introduced in v6.45);
*) cloud - properly stop "time-zone-autodetect" after disable;
*) interface - fixed missing PWR-LINE section on PL7411-2nD and PL6411-2nD (introduced v6.44);
*) ipsec - added "connection-mark" parameter for mode-config initiator;
*) ipsec - allow peer argument only for "encrypt" policies (introduced in v6.45);
*) ipsec - fixed peer configuration migration from versions older than v6.43 (introduced in v6.45);
*) ipsec - improved stability for peer initialization (introduced in v6.45);
*) ipsec - show warning for policies with "unknown" peer;
*) ospf - fixed possible busy loop condition when accessing OSPF LSAs;
*) profile - added "internet-detect" process classificator;
*) radius - fixed "User-Password" encoding (introduced in v6.45);
*) ssh - do not enable "none-crypto" if "strong-crypto" is enabled on upgrade (introduced in v6.45);
*) ssh - fixed executed command output printing (introduced in v6.45);
*) supout - fixed supout file generation outside of internal storage with insufficient space;
*) upgrade - fixed "auto-upgrade" to use new style authentication (introduced in v6.45);
*) vlan - fixed "slave" flag for non-running interfaces (introduced in v6.45);
*) wireless - improved 802.11ac stability for all ARM devices with wireless;
*) wireless - improved range selection when distance set to "dynamic";
Verze 6.45.2
Minimálně u 4011 je problém s SFP. Po upgradu na 4011 přestanou být vidět SFPčka. Jako kdyby tam nic nebylo.
Potvrzuji info od peckma. Problém s RB4011 je jak na 6.45.2, tak i na 6.45.1. Nedetekuje to ani originální 1Gb Mikrotik SFP moduly. Po downgradu na 6.44.5 je vše OK.
https://forum.mikrotik.com/viewtopic.ph ... 42#p740566
aneb proč chodit kolem horké kaše když můžu rovnou ke zdroji.
