What's new in v6.40 (2017-Jul-21 08:45):
!) lte - added initial fastpath support (except SXT LTE and Sierra modems);
!) lte - added initial support for passthrough mode for lte modems that supports fastpath;
!) wireless - added Nv2 AP synchronization feature "nv2-modes" and "nv2-sync-secret" option;
bonding - fixed 802.3ad mode on RB1100AHx4;
btest - fixed crash when packet size has been changed during test;
capsman - added "current-registered-clients" and "current-authorized-clients" count for CAP interfaces;
capsman - fixed EAP identity reporting in "registration-table";
capsman - set minimal "caps-man-names" and "caps-man-certificate-common-names" length to 1 char;
certificate - added "crl-use" setting to disable CRL use (CLI only);
certificate - update and reload old certificate with new one if SKID matches;
chr - fixed MAC address assignment when hot plugging NIC on XenServer;
chr - maximal system disk size now limited to 16GB;
conntrack - fixed IPv6 connection tracking enable/disable;
console - fixed different command auto complete on <tab>;
crs212 - fixed Optech sfp-10G-tx module compatibility with SFP ports;
defconf - added IPv6 default firewall configuration (IPv6 package must be enabled on reset);
defconf - improved IPv4 default firewall configuration;
defconf - renamed 192.168.88.1 address static DNS entry from "router" to "router.lan";
dhcp - added "debug" logs on MAC address change;
dhcpv4-client - added "gateway-address" script parameter;
dhcpv4-server - fixed lease renew for DHCP clients that sends renewal with "ciaddr = 0.0.0.0";
dhcpv4-server - fixed server state on interface change in Winbox and Webfig;
discovery - fixed timeouts for LLDP neighbours;
dns - remove all dynamic cache RRs of same type when adding static entry;
dude - fixed server crash;
email - added support for multiple attachments;
ethernet - fixed occasional broken interface order after reset/first boot;
ethernet - fixed rare linking problem with forced 10Mbps full-duplex mode;
export - added "terse" option;
export - added default "init-delay" setting for "/routerboard settings" menu;
export - added router model and serial number to configuration export;
export - fixed "/interface list" verbose export;
export - fixed "/ipv6 route" compact export;
export - fixed MPLS "dynamic-label-range" export;
export - fixed SNMP "src-address" for compact export;
fastpath - improved performance when packets for slowpath are received;
fastpath - improved process of removing dynamic interfaces;
fasttrack - fixed fasttrack over interfaces with dynamic MAC address;
fetch - added "src-address" parameter for HTTP and HTTPS;
filesystem - improved error correcting process on tilera and RB1100AHx4 storage;
firewall - added "none-dynamic" and "none-static" options for "address-list-timeout" parameter;
firewall - fixed bridge "action=log" rules;
firewall - fixed cosmetic "inactive" flag when item was disabled;
firewall - fixed crash on fasttrack dummy rule manual change attempt;
firewall - removed unique address list name limit;
hAP ac lite - removed nonexistent "wlan-led";
hotspot - added "address-list" support in "walled-garden" IP section;
hotspot - require "dns-name" to contain "." symbol under Hotspot Server Profile configuration;
ike1 - added log error message if netmask was not provided by "mode-config" server;
ike1 - added support for "framed-pool" RADIUS attribute;
ike1 - create tunnel policy when no split net provided;
ike1 - fixed minor memory leak on peer configuration change;
ike1 - kill phase1 instead of rekey if "mode-config" is used;
ike1 - removed SAs on DPD;
ike1 - send phase1 delete;
ike1 - wait for cfg set reply before ph2 creation with xAuth;
ike2 - added RADIUS attributes "Framed-Pool", "Framed-Ip-Address", "Framed-Ip-Netmask";
ike2 - added pfkey kernel return checks;
ike2 - added support for "Mikrotik_Address_List" RADIUS attribute;
ike2 - added support for "mode-config" static address;
ike2 - by default use "/24" netmask for peer IP address in split net;
ike2 - fixed duplicate policy checking with "0.0.0.0/0" policies;
ike2 - prefer traffic selector with "mode-config" address;
ipsec - added "firewall=add-notrack" peer option (CLI only);
ipsec - added information in console XML for "mode-config" menu;
ipsec - added support for "key-id" peer identification type;
ipsec - allow to specify chain in "firewall" peer option;
ipsec - do not deduct "dst-address" from "sa-dst-address" for "/0" policies;
ipsec - enabled modp2048 DH group by default;
ipsec - fixed connections cleanup on policy or proposal modification;
ipsec - optimized logging under IPSec topic;
ipsec - removed policy priority;
l2tp - fixed handling of pre-authenticated L2TP sessions with CHAP authentication;
l2tp-server - added "one-session-per-host" option;
log - added "poe-out" topic;
log - improved "l2tp" logs;
log - optimized "wireless,info" topic logs;
log - work on false CPU/RAM overclocked alarms;
lte - added "accounting" logs for LTE connections;
lte - added additional driver support for DWR-910;
lte - added info command support for the Jaton LTE modem;
lte - added initial support for "NTT DoCoMo" modem;
lte - added support for Huawei E3531-6;
lte - added support for ZTE TE W120;
lte - fixed info command when it is executed at the same time as modem restarts/disconnects;
lte - improved SMS delivery report;
lte - improved reliability on SXT LTE;
metarouter - fixed display of bogus error message on startup;
mmips - added support for NVME disks;
ovpn - added support for "push-continuation";
ovpn - added support for topology subnet for IP mode;
ovpn - fixed duplicate default gateway presence when receiving extra routes;
ovpn - improved performance when receiving too many options;
packages - increased automatic download retry interval to 5 minutes if there is no free disk space;
ping - fixed ping getting stuck (after several thousands of ping attempts);
ppp - added initial support for ZTE K4203-Z and ME3630-E;
ppp - added output values for "info" command for finding the GSM base station's location ("LAC" and "IMSI");
ppp - fixed "user-command" output;
ppp - fixed non-standart PAP or CHAP packet handling;
ppp - improved MLPPP packet forwarding performance;
ppp - use interface name instead of IP as default route gateway;
proxy - fixed potential crash;
proxy - fixed rare program crash after closing client connection;
quickset - added "Band" setting to "CPE" and "PTP CPE" modes;
quickset - added special firewall exception rules for IPSec;
quickset - fixed incorrect VPN address value on arm and tilera;
quickset - simplified LTE status monitoring;
quickset - use active user name and permissions when applying changes;
rb1100ahx4 - fixed startup problems (requires additional reboot after upgrade);
rb3011 - fixed packet passthrough on switch2 while booting;
rb750gr3 - fixed USB power;
routerboard - added "caps-mode" option for "reset-configuration";
routerboard - added "caps-mode-script" for default-configuration print;
routing - allow to disable "all" interface entry in BFD;
safe-mode - fixed session handling when Safe Mode is used on multiple sessions at the same time;
sfp - fixed invalid temperature reporting when ambient temperature is less than 0;
sms - decode reports in readable format;
sniffer - do not skip L2 packets when "all" interface mode was used;
snmp - added "ifindex" on interface traps;
snmp - added CAPsMAN interface statistics;
snmp - added ability to set "src-address";
snmp - fixed "/system resource cpu print oid" menu;
snmp - fixed crash on interface table get;
snmp - fixed wireless interface walk table id ordering;
socks - fixed crash while processing many simultaneous sessions;
ssl - added Wildcard support for "left-most" DNS label (will allow to use signed Wildcard certificate on VPN servers);
supout - fixed IPv6 firewall section;
switch - fixed "loop-protect" on CRS SFP/SFP+ ports;
switch - fixed multicast forwarding on CRS326;
tile - fixed copying large amount of text over serial console;
tr069-client - fixed lost HTTP header on authorization;
trafficgen - added "lost-ratio" to statistics;
ups - show correct "line-voltage" value for usbhid UPS devices;
userman - added "/tool user-manager user clear-profiles" command;
userman - do not send disconnect request for user when "simultaneous session limit reached";
userman - lookup language files also in "/flash" directory;
vlan - do not delete existing VLAN interface on "failure: already have such vlan";
webfig - fixed wireless "scan-list" parameter not being saved after applying changes;
winbox - added "eap-identity" to CAPsMAN registration table;
winbox - added "no-dad" setting to IPv6 addresses;
winbox - added "reselect-channel" to CAPsMAN interfaces;
winbox - added "session-uptime" to LTE interface;
winbox - added TR069 support;
winbox - do not autoscale graphs outside known maximums;
winbox - fixed wireless interface "amsdu-threshold" max limit;
winbox - hide LCD menu on CRS112-8G-4S;
winbox - make IPSec policies table an order list;
winbox - moved LTE info fields to status tab;
winbox - show "/interface wireless cap print" warnings;
winbox - show "/system health" only on boards that have health monitoring;
winbox - show "D" flag under "/interface mesh port" menu;
wireless - NAK any methods except MS-CHAPv2 as inner method in PEAP;
wireless - added option to change "nv2-downlink-ratio" for nv2 protocol;
wireless - added option to set "fixed-downlink" mode for nv2 protocol;
wireless - allow VirutalAP on Level0 (24h demo) license;
wireless - always use "multicast-helper" when DHCP is being used;
wireless - do not skip >2462 channels if interface is WDS slave;
wireless - fixed 802.11u wireless request processing;
wireless - fixed EAP PEAP success processing;
wireless - fixed compatibility with "AR5212" wireless chips;
wireless - fixed rare crash on cap disable;
wireless - fixed registration table "signal-strength" reporting for chains when using nv2;
Verze 6.40
- zdenek.svarc
- Administrator
souhlasím, že oprav přišlo hodně. Zkusili jsme na části sítě a 4 desky 912UAG sice fungují a propouští data, ale nevykonávají příkazy, nejdou ani rebootnout. Bude se muset na místo zkusit vyp. / zap. U jedné desky se ztratil balíček wireless a u další se změnilo SSID a z karta ztratila nastavení IP adresy.
Takže z cca 50 desek po upgradu 6 chyb. To není moc pozitivní. Jaké máte zkušenosti? Nechce se mi to zatím moc pouštět do zbytku sítě.
k3dt píše:Na test upgrade cca 100 zarizek z 6.38.3 a neumrelo ani jedno.
Souhlasim, upgrade RB912, RB922, hap, sxt lite a/n, sxt lite ac a vse jede. Prechod z verze 6.39.1 nebo 6.39.2.
Nevím co se děje ale od verze R.O. 6.38 mám potíže s master portami na desce RB1200 , do této verze to chodilo v pohodě , když se do portů které jsou v master portu strčí cokoliv jiné než druhý MK (RB600) tak fungují , jakmile se zapojí RB600 s adresou ve stejné podsíti do portů které jsou v master portu a ten RB600 je v bridge , prostě ani si nepingne na ten 1 MK (RB1200) , ale když se mu dá dhpc client najednou to funguje , když porty vyhodím z Master Portu a dám je do bridge vše funguje , nastavený mám vše dobře ..... Co jsem dál zpozoroval : jakýkoliv port který vede v RB1200 do switche AR8327 protáhne jen 20Mb , kdežto port který vede do cpu protáhne plný gigabit , je to zajímavé .... Setkal jste se někdo s tím ...
Zkoušel jste někdo tu NV2 synchronizaci? Zkušenosti?
kadlcikales píše:Nevím co se děje ale od verze R.O. 6.38 mám potíže s master portami na desce RB1200 , do této verze to chodilo v pohodě , když se do portů které jsou v master portu strčí cokoliv jiné než druhý MK (RB600) tak fungují , jakmile se zapojí RB600 s adresou ve stejné podsíti do portů které jsou v master portu a ten RB600 je v bridge , prostě ani si nepingne na ten 1 MK (RB1200) , ale když se mu dá dhpc client najednou to funguje , když porty vyhodím z Master Portu a dám je do bridge vše funguje , nastavený mám vše dobře ..... Co jsem dál zpozoroval : jakýkoliv port který vede v RB1200 do switche AR8327 protáhne jen 20Mb , kdežto port který vede do cpu protáhne plný gigabit , je to zajímavé .... Setkal jste se někdo s tím ...
Noo, psalo to v changelogu, neco o tom, ze nastaveni a-la mester port nebude podporovano. Precti si changelog (tusim, ze pro RC verze - tam to najdes - zmena je od 6.38.5rc??)
O master portu se v 6.38 moc nepíše.
Co bych viděl hůře, je verze 6.41. Tam se to opravdu měnit bude, asi už nebude rozdíl mezi bridge a switchem, co půjde, bude konfigurováno na switchi. A co jsme dnes konfigurovali na switchi, budeme nastavovat na bridgi. Vůbec si neumím představit, kolik verzí jim bude trvat stabilizace této funkce.
honza198 píše:kadlcikales píše:Noo, psalo to v changelogu, neco o tom, ze nastaveni a-la mester port nebude podporovano. Precti si changelog (tusim, ze pro RC verze - tam to najdes - zmena je od 6.38.5rc??)
to ludvik:
to nam zase pribude vrasek na cele nez to odladej Osobne se zas na nejakou dobu prepinam do konzervativnich rezimu
honzam píše:Zkoušel jste někdo tu NV2 synchronizaci? Zkušenosti?
nejak ji nemuzu najit ? od ktery verze a kde to je?
a hledáš ve CLI?
