http://download.mikrotik.com/swos/swos-rb260-1.12.lzb
What's new in 1.12:
*) fixed problem - SFP port stops after ethernet port cfg change (RB260 only);
*) change default vlan mode on RB260 to 'optional';
*) fixed problem - SNMP worked even when disabled;
*) fixed problem - SFP autonegotiation setting was not saved (RB260 only);
*) fixed uptime to be correct;
*) fixed RB260GSP poe-out to work correctly after downgrade & upgrade back;
What's new in 1.11:
*) added support for RB260GSP;
SWOS 1.12
to je vsechno hezke ale ma to existencni potize s SFP sachtou viz http://forum.mikrotik.com/viewtopic.php ... 57#p422703
What's new in 1.13:
*) allow to disable SFP port;
*) do not disable SFP port if loss of signal is detected, some SFP modules
do not report it correctly;
*) make autonegotiation work better;
soudruzi mysli ze uz to opravili ... tak jsem zvedavy ...
