What's new in 6.8 (2014-Jan-28 10:19):
*) bridge - default protocol-mode changed to RSTP for new bridges,
fixed bridge mac address changing when port (with lowest mac address) goes down
*) userman - improve startup time;
*) sstp client - support server name verification from certificate;
*) wireless - improved 11n and nv2 stability;
*) dhcp client - support interfaces in bridge;
*) dhcp - parse decimal strings and IP addreses in options value;
*) bgp - don't show community 'internet' in BGP advertisements;
*) ipsec - enable hardware acceleration for aes-cbc + md5|sha1|sha256 aead on tilera cpus;
*) ospf - fixed checksum calculation for OSPFv3 AS-external-LSAs;
*) default configuration - changed dhcp server lease time to 10 minutes;
*) fixed port isolation on CRSs (bug introduced in v6.6);
*) smb - added support for SMB 2.002
*) timezone information updated;
*) ppp - fixed ppp bridging (did not work since v6.6);
*) improved speed of PPP, PPPoE, PPTP & L2TP on multicore routers;
*) address-list - fix crash when adding two identical address list entries (not allowed any more);
*) fixed multicast forwarding on CCRs;
*) firewall - improved address-type matcher, and added it for ipv6 aswell;
Verze 6.8
ale link jede http://download2.mikrotik.com/routeros/6.8/all_packages-mipsbe-6.8.zip , to sou tezci amateri jen stahnout info a odkaz a nechat soubor na miste.
To jo i upgrade přímo z MK funguje. Schválně jsem zvědavej jestli se bude lišit čas buildů až to tam daj znova - jestli ještě něco ladili koumáci
after updating Firmware 3.11 aren't loaded any more
it is checked on several RB751U-2HnD !!!!!!!!!!!!!!!!!!!!!!!!!
After upgrade OmniTik-UPA to 6.8 and firmware to 3.11, it died, after inspection on the site, we found port flapping.
affected CPE SXT (6. still crashing under load (10/10Mbit udp btest) after 10s
Sxt lite 5 - upgrade OK.
Bios 3.11 to ani nenabízí...
Toto nemohu potvrdit. BW test mám pustený klidne minutu a nic
affected CPE SXT (6.8 ) still crashing under load (10/10Mbit udp btest) after 10s
Bios zatím pro Lite řadu ani neni, jen pro klasický SXT, OmniTik atd...
S tím BW testem ještě něco dělali teď odpoledne - s tou první verzí to dělalo docela haluze.
S Mikrotikem je dneska docela sranda - opět neni verze 6.8 "dostupná"
Dokonce i upgrade přímo z MK nefunguje - to už je vážný
tak sem se na v6.8 těšil a teď i když vyjde tak jí asi nechám bejt.
Taky jsem byl pln očekávání hlavně kvůli wifině a oni zas pokurví tunu jiných věcí...
pani... ja normalne lutujem tych, ktory ostali verny routeros aj co sa tyka wifi casti...
vsak oni robia jednu hovadinu za druhou. normalne je to, ze sa niekedy nieco nepodari vyladit vo FW. ale u nich je normalne to, ak sa niekedy NAHODOU nieco podari vyladit, resp. dotiahnut do konca.
pisou ti, kterym se co 5min odpojuji klienti, bo DFS, ze?
ale no flame, tohle sem fakt nepatri!
Jan Ptáček
ale patří. Teď spravuju nejednu jednu síť na UBNT a chce se mi zvracet. To že UBNT vydává jednu verzi za půl roku je nejspíš tím že tam maji v tom hovno tak se nemá co postrat.
